TPMS Test/Program Before Installing?
Old Mar 17, 2015 | 01:06 PM
JGeezer's Avatar
JGeezer
Cruising
Default TPMS Test/Program Before Installing?
I'm a bit paranoid about the two generations of TPMS on our C5's, and this eBay claims to be the right one for my 2003:
http://www.ebay.com/itm/131443678234?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Before I go though the install expense, I wanted to test that they really are the correct ones, so just holding one in my hand I tried programming with the magnet, and cannot get a beep. Tried again with a second one, nada.
SO - should this work? should you be able to program an uninstalled TPMS? Or are these people (and their sensor) wrong?
Old Mar 17, 2015 | 01:25 PM
65GGvert's Avatar
65GGvert
New Set of 4 Orange TPMS Tire Pressure Monitoring Sensor SC2575 15136883 | eBay
Yes you should be able to program them in your hands. I'd mark them in order lf, rf, rr, and lr if you get them to work and then install them in the correct position when you install them and they will already be programmed. Try a stronger magnet. In the meantime, I'll check the part number for your car.
Old Mar 17, 2015 | 01:27 PM
65GGvert's Avatar
65GGvert
Sorry, I can't tell you if those are correct. The GM number is 25773946. You can buy from Gene Culley at Cultrag and get the correct sensors cheaper than from a dealer.
Old Mar 17, 2015 | 02:00 PM
JR-01's Avatar
JR-01
I bought the OEM units and am glad I did.
Old Mar 17, 2015 | 02:52 PM
65GGvert's Avatar
65GGvert
The end of their ad says "these sensors require programming by a dealer or tire shop", so who knows?
Old Mar 17, 2015 | 03:57 PM
JR-01's Avatar
JR-01
Originally Posted by 8VETTE7
OP,
Here is a link to a thread from late 2012 by a member that bought the "Orange" brand of TPMS for his C5:
https://www.corvetteforum.com/forums...-learning.html
After a significant effort to program the TPMS all of which failed he ended up buying Schrader TPMS and returning the Orange brand.............
That's what I would do. I bought the Schraders, had tire shop install them when I bought new tires and trained them myself with a magnet in about 2 minutes.
Old Mar 18, 2015 | 09:44 AM
JGeezer's Avatar
JGeezer
Cruising
Thanks guys!
I have determined they are the wrong sensors, and that the vendor's eBay fitment info is wrong. These are their SC2575 (Schrader 20115 equivalent), the correct Orange sensor is their SC3946 which they say is GM P/N 25773946 equivalent.
http://www.ebay.com/itm/NEW-Set-of-4...6870dc&vxp=mtr
It sure would be nice to only spend $79.95 for a set of four; I'll let you know how good they are with handling the exchange and if these correct ones do, in fact, work.
BTW, not made in China, these are marked Taiwan if you consider that a small step closer
Old Mar 18, 2015 | 01:34 PM
wspo's Avatar
wspo
Thanks guys!
I replaced 3 of the TPMS on my 2002 coupe (one was replaced by previous owner) with Orange part number SC 3946 purchased on Ebay. I did not have any problem programing the sensors. Orange Electronics makes OEM sensors for Mercedes and several others others. To the naked eye the quality looks good and they come with nut, gasket and valve cap. If I read the date codes correctly the sensors I bought were made in June 2008. This may explain the low Ebay price. The batteries used have a long shelf life so I am not worried about the build date. Only had them on since September 2014 so time will tell.
Old Mar 18, 2015 | 05:41 PM
bjones7131's Avatar
bjones7131
I got the dorman brand from rockauto, lifetime warranty. I trained them before installation, one wouldn't train and had to send back. All good after 6 months.
Old Mar 18, 2015 | 08:41 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thank you for the referral. We would certainly be happy to help out!
To TPMS Test/Program Before Installing?
