Orange Electronic TPMS learning?
Old Nov 26, 2012 | 12:26 PM
sbulla's Avatar
sbulla
Default Orange Electronic TPMS learning?
I recently installed new OE wheels on my '04 CE vert along with new Orange Electronic TPMS. So far I've not been able to get a single sensor to respond to the magnet learning procedure outlined here on this forum. I've tried four different magnets I had lying around my shop from an old CB antennae mag mount, one off the back of a speaker, a couple of strong bar magnets purchased from Radio Shack, and a screwdriver magnetizer. I held these magnets in multiple positions on each wheel also.
Just to make sure I ordered the right sensors, I double checked the OE Wheels web site and checked the part # with what I had and checked that with other sites that sell the Orange unit.
While I was on the OE Wheels site that I ordered them from, I noticed they had an "install" tab on the order page for the TPMS and it stated...
1. Turn ignition switch to ON position (engine off)
2. Press and hold unlock and lock buttons on the keyless entry transmitter; until horn sounds and then LF turn signal will become illuminated.
3. Starting with LF tire increase/decrease, tire pressure until horn sounds.
4. After horn sounds proceed as in step 5 for the next 3 sensors in the following order RF RR LR After completing LR tire horn will sound twice.
5. Turn ignition to OFF position to exit vehicle learn mode. Adjust all tires to pressure listed on the placard.
Well, I thought I'd try this but nothing happened while holding the buttons on my transmitter.
I, also, tried the pressure varying while in the regular learning procedure to no avail.
Any suggestions as to what to try next? I would hate to think that the tire installers broke every single sensor but, if nothing else works, I guess it's back to them to find out.
Sonny
Old Nov 26, 2012 | 12:55 PM
lionelhutz's Avatar
lionelhutz
That procedure is wrong.
If you can't get it to learn then you either need a bigger magnet or the sensors are no good. I use a 1" x 2" x 3" ceramic bar magnet. I can hold it by the valve stem and it works no problem.
Old Nov 26, 2012 | 01:33 PM
sbulla's Avatar
sbulla
If I can't find another, stronger magnet, I may just take it by a dealership and see what they can do.
Thanks,
Sonny
Old Nov 26, 2012 | 02:39 PM
clegg's Avatar
clegg
Use this procedure copied from this site;
TPMs. 1) Turn ignition on 2) Press "Reset" button in order to clear any IPC display warning messages 3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank 4) Press and hold the DIC "Reset" button for 3 seconds 5) Press the "Options" button again until TIRE TRAINING message appears 6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming 7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (large magnet will do) over the left front valve stem 8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again, it will give you three tries. Then you must start over) 9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear Tire Programming can be canceled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is canceled with less than 4 sensors learned, it will only accept the codes programmed up to that point.
Old Nov 26, 2012 | 02:41 PM
clegg's Avatar
clegg
Mine programmed with a telescoping pick up magnet.
Old Nov 26, 2012 | 02:57 PM
PhilsFRC's Avatar
PhilsFRC
I think the orange (reddish orange) sensors are OEM Schrader. Mine are the early ones-p/n 28006. Yours should be p/n 20117:
http://www.schraderinternational.com...ette&year=2004
Double check the part number-MAY be incorrect.
Old Nov 26, 2012 | 03:43 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
That is not the correct procedure to program 2001-2004 TPMS sensors.
Use the procedure that clegg posted to program them. It is also outlined in your owner's manual.
Old Nov 26, 2012 | 04:07 PM
jrose7004's Avatar
jrose7004
I'll bet if you take it to a tire shop, they can program them for you.
Old Nov 26, 2012 | 05:44 PM
sbulla's Avatar
sbulla
That's the procedure I used. No response from the sensors with any magnet I had on hand.
Sonny
Old Nov 26, 2012 | 05:47 PM
sbulla's Avatar
sbulla
The brand name of these I have is Orange Electronic. They're not physically the color orange. As a matter of fact, they're black.
Sonny
Old Nov 26, 2012 | 05:48 PM
sbulla's Avatar
sbulla
Originally Posted by 8VETTE7
You might try placing the magnet inside the barrel just behind the stem. That's how I do mine.
Tried that location with all the magnets to. No joy.
Sonny
Old Nov 26, 2012 | 06:35 PM
PhilsFRC's Avatar
PhilsFRC
Never heard of Orange Electronic and then searched:
http://www.orange-electronic.com/index_tw.html
Looks like a great CHINESE company-not that there's anything wrong with that-the wife's from Shanghai. Looking further these sensors are about half the price of the Schraders, which are in turn almost half the price of GM. You may have a part QUALITY problem. My $.02.
Old Nov 27, 2012 | 04:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The STEM of the sensor does NOTHING for the sensor except to hold it in place and allow air IN & OUT of the tire. The sensor actually have a small reed switch that gets actuated by a MAGNET or CENTRIFICAL FORCE (tire rotation ) This is what turns the sensor ON and OFF to conserve battery power when the car is not in use or to turn the sensor on when programming.
When you place the magnet on the sensor. you really need to place it ON THE RIM over the sensor where the sensor is positioned:
There TWO different sensors. 97-2000 & 2001-2004 You can NOT use one that is not for your year series C5. Did they send you an early or late mod sensor??
Do you have the early sensors or late model sensors?
Old Nov 27, 2012 | 04:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is a picture of an early sensor:
Early vs Late
If the sensors that you purchased do not operate on the same frequency as the old ones or the frequency that your RFA module operates on, the sensors will not work. If its an aftermarket sensor, it can look like a late model sensor and actually transmit the early frequency.
BC
Old Nov 27, 2012 | 05:38 PM
sbulla's Avatar
sbulla
BC
These are 315 mhz. What is the receiver frequency supposed to be on my '04?
Here is the page I ordered from...
http://oewheelsllc.com/TPMS-Sensors_...ssure-Sensor_2
There has got to be something wrong because I found a VERY strong magnet today and still not a single sensor triggered the horn.
Sonny
Old Nov 27, 2012 | 05:45 PM
PhilsFRC's Avatar
PhilsFRC
Default Frequency ID
Don't know if this will help, but the ID information on my early sensors (Schrader, not yet installed) are as follows:
328006 DC
315FM 63PSI
ASIC No. 02073923
FCC ID: MRXGMG2R3FM
IC: 2546A-GMG2R3FM
MODEL: GMG2R3FM
I would assume if these codes are on yours, you have the incorrect sensors. I picked up one of these to "learn" them:
http://www.amazon.com/Schrader-20143.../dp/B004A42MZI
Old Nov 27, 2012 | 05:46 PM
PhilsFRC's Avatar
PhilsFRC
While I was posting you showed 315mhz. From the data on mine, it would appear you got the WRONG ones.
To Orange Electronic TPMS learning?
Old Nov 27, 2012 | 05:58 PM
sbulla's Avatar
sbulla
What I was going by was the fact that they stated on the order page that these "replaced the oe part# 25773946" and I checked that it was the correct GM part number for my sensors.
I'll be pissed if I have to break down each tire again but, I want them to work!
Sonny
Old Nov 27, 2012 | 06:01 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
The early model is wider, like the ones shown in the photo you linked sbulla. The later 01-04 is usually narrower, like the ones shown in Bill's photos. That's not to say you might not be able to buy new ones and have them look like the old style, but they look wrong to me. Mine that I bought new from Ebay looked more like the ones I took off (like yours, but my car is older).
It doesn't appear to me that you ordered the wrong ones, but, it does appear as if they have the wrong ones on that page. Might check with the place and see what they say. If you get another set, you may consider programming them before you take them to a tire shop. You can just sit in the drivers seat and make sure they're good to go before paying to have them installed. That's what I did. All 4 were ready to go before I took them in. Then, just reprogram them after installation to get the right ones recognized at the proper 4 corners of the car.
PhilsFRC's Avatar
PhilsFRC
From what I'm reading, prepared to be pissed. I got mine from Amazon-here are yours:
http://www.amazon.com/Schrader-20117.../dp/B002GYSP8C
