Orange Electronic TPMS learning?
Old Dec 2, 2012 | 04:37 PM
  #61
QCVette's Avatar
QCVette
Active Streak: 90 Days
Originally Posted by K-Spaz
Why not just get a sensor that DOES work, and try it. BEFORE breaking the tires down, then resolve it. You could even go to a friend or dealer with another Vette, park close, and program your car those sensors. It'll be enough to see that the rest of your system is working. From there, purchase the right ones, and be done with this.
Just find another C5 ('01-'04) and program yours with their sensors. If you park next to them it will be close enough to try out. This will tell you if your system is working.
I did the same thing with my '99. I used the wheels on another '99 and found it programmed correctly so I knew it was my sensors that were bad.
Old Jun 24, 2013 | 01:30 PM
  #62
RichF's Avatar
RichF
St. Jude Donor '03, '04 & '05
Hi Sbulla:
What ever happened with your Orange Electronic sensors? Just found your post.. I had new tires and [Orange Electronic] tpms sensors on my 2004 convertible .. installed by a well known "tire place". I cannot get the sensors to retrain either. Tried many different magnets, positioning of said magnets, and even tried bringing pressure down to 8lbs. .. no beep.. Do not really want to have them pull run-flats back off the rims though. Ironically, I gave the tech the GM part number, and wound up with these things.. and only found out later ( My wife brought the car in and picked up) What did you finally do? Thanks.
Old Jun 24, 2013 | 01:51 PM
  #63
sbulla's Avatar
sbulla
Originally Posted by RichF
Hi Sbulla:
I finally had to break down the tires and replace them with some schrader tpms and returned the orange units back to the supplier. The schraders worked the first time.
Good luck,
Sonny
Old Jul 5, 2013 | 10:27 PM
  #64
RichF's Avatar
RichF
Thanks!
