BPP Short Shifter Question
Old Mar 17, 2015 | 10:03 PM
fffttt1's Avatar
fffttt1
Default BPP Short Shifter Question
Bought a used BPP shifter and disassembled to clean, inspect and relube. Noted the round pivot pin that goes through the shifter lever is ~1/8" longer on one side. Is this normal or has the pin moved? The longer side was on the left side of the housing as installed.
Thanks, Ray in TX.
Old Mar 18, 2015 | 05:06 PM
fffttt1's Avatar
fffttt1
TTT ......anyone?
Old Mar 18, 2015 | 08:22 PM
fffttt1's Avatar
fffttt1
OK....was cleaning cover and discovered two more metal discs. Understand now disc and rubber on each end of springs. Ernie @ BPP indicated that it doesn't matter if rubber disc seats against spring or housing/cover. He had no answer for the pivot pin being slightly longer on one side. Anyone else notice this length descrepancy on their BPP shifter?
Thanks, Ray in TX.
To BPP Short Shifter Question
