drive on ramps
Old Mar 22, 2015 | 10:15 AM
jim wannavet's Avatar
jim wannavet
St. Jude Donor '15-'16
Default drive on ramps
anyone have drive on ramps that were bought that work on a c5 or did you make your own.
Old Mar 22, 2015 | 11:27 AM
j.grif's Avatar
j.grif
Do you mean like these, bought at Harbor freight and made in America.
Old Mar 22, 2015 | 11:35 AM
jim wannavet
can you change oil with the car on those.those are the ones I was looking at.thanks
Old Mar 22, 2015 | 11:36 AM
johnson-rod's Avatar
johnson-rod
Rhino ramps. The truck ones are a little wider so your tires don't hang over the sides.
I lay a 2X6 in front to help getting up without hurting the air wings. Coming down it's not a problem.
Old Mar 22, 2015 | 11:53 AM
SuperVetteC5's Avatar
SuperVetteC5
Built my own yesterday. Don't want to tear up front air dam rub anything. They have to be long in order to accomplish that. Can easily and safely get under the front of the car using them. However, when changing the oil, you really need the car level or slightly higher in the rear because drain plug is in the front of the pan.
Old Mar 22, 2015 | 12:00 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Couple of pics from a Race Ramps display. I have never used them but the concept looks good.
Old Mar 22, 2015 | 12:07 PM
j.grif's Avatar
j.grif
Yes, you can change the oil with these ramps, but you have to jack the back up to a level position to effectively get all of the oil out, there are threads about which parts to put jacks/supports under. Some guys have resorted to making full length ramps to accomplish that without using jacks and stands.
Old Mar 22, 2015 | 12:27 PM
SuperVetteC5
Yup, that is the next step for what I'm building.
Old Mar 22, 2015 | 12:33 PM
SuperVetteC5
But I think I'm gonna get these instead.
Old Mar 22, 2015 | 12:41 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I had the plastic Harbor Freight ones and with the steep front angle they didn't work for me...
I then fabbed a set from wood and they slid on the garage floor.
For some reason my bride loves me and I ended up with a Kwik-Lift.
Old Mar 22, 2015 | 01:12 PM
bumble-z's Avatar
bumble-z
My wife doesn't love me so I had to make my own.
Old Mar 22, 2015 | 04:16 PM
jr105's Avatar
jr105
This is something I saved from when I had a C3. I never built them because of limited space to store them, but I have a second garage now so I may give them a shot this summer.
http://corvettec3.ca/ramps.htm
Old Mar 22, 2015 | 05:28 PM
jim wannavet
thanks everyone.some great ramps store bought and homemade.the homemade look like kwik lift.the quick lift b3500 I found on another thread had mostly good reviews but also some negative like everything.like to get a 2 post lift quite pricey.
Old Mar 22, 2015 | 06:39 PM
Jeff T.'s Avatar
Jeff T.
When mine saw my wood ramps sliding she panicked... Sometimes panic is good!
Old Mar 22, 2015 | 09:04 PM
SuperVetteC5
Rubber grippers on the bottom of the wood is necessary.
Old Mar 22, 2015 | 09:11 PM
apriliacati's Avatar
apriliacati
I have the race ramps for my Z06, works perfectly without any scrapping.
Old Mar 22, 2015 | 09:39 PM
Jeff T.'s Avatar
Jeff T.
Firewood now!
To drive on ramps
Old Mar 22, 2015 | 11:16 PM
Race Ramps is a very good product, but I can only imagine what a setup like that would cost.
Old Mar 22, 2015 | 11:48 PM
WICKEDFRC's Avatar
WICKEDFRC
I broke down and ordered the Race Ramps RR-78 which has a 12" high platform and 14" wide base.
Problem is, I wanted this height and width, but it is not available in the RR-87 version. The RR-87 is only a 10" high platform.
The RR-78 set up requires the use of the Extenders for my C6 Z06 at stock ride height. And while I do appreciate the height and width offered by the RR-78 set up, I simply cannot justify the additional expense for an "add on" piece to make my ramps most efficient.
The advantages of the RR-78 should be available on the RR-87 so the RR-87 could be ordered in two versions. A 10" high version or a 12" high version.
It's the length of the ramps and the incline that got me after purchasing the higher of the two. The height of the 12" platform is excellent. It provides plenty of room to work under the Vette. While underneath the Z, I was laying on my side behind the oil filter and my shoulders were just grazing the undercarriage. So the extra 2" height over the 10" height of the RR-87 is welcomed.
As to what one should do or get....well, I will testify that moving wooden ramps around (no matter how great they are made) are heavy. The Race Ramps are very light, easily maneuverable, and can be separated to allow free workspace at the sides of the vehicle. Unless wood ramps are sectioned, this may pose an inconvenience
If I could, I would have requested custom Race Ramps be built in the 87" length, 12" height, 14" width, and separate at the wheel platform like other RR two-piece designs do.
Although my ramps work well (but require wood assists), I do not want a 3-piece design. It's just more stuff to be storing and moving around.
Good luck.
Old Mar 23, 2015 | 07:32 AM
runner140*'s Avatar
runner140*
Had a set of Rhino ramps, hated them and got a set of RaceRamps.
Worth every dime.
