torque wrench recommendations
Old Mar 31, 2015 | 06:30 PM
jim wannavet's Avatar
jim wannavet
St. Jude Donor '15-'16
Default torque wrench recommendations
any recommendations on a decent torque wrench brand that wont break the bank.thanks jim
Old Mar 31, 2015 | 09:36 PM
I've been using a Sears Craftsman clicker type torque wrench for years. Has always served me well.
Old Mar 31, 2015 | 10:55 PM
grantv's Avatar
grantv
X2. My Craftsman has been in my toolbox for many years. Long enough that I should probably have it calibrated.
Heard good things about the Harbor Freight units including a positive review by Hot Rod.
Don't forget to always back off and unlock when done.
Old Mar 31, 2015 | 11:31 PM
tommypenguin's Avatar
tommypenguin
X3 for Craftsman. I have a Snap On one as well, but for a good balance of quality/price you can't go wrong with craftsman. Just remember to loosen the tension at the end of each use.
Old Apr 1, 2015 | 12:17 AM
Choreo's Avatar
Choreo
Not much help here - all three of mine are Snap-On - two Digital and one Clicker(which I don't use anymore)... pretty pricy.
If you are doing a lot of work on the car to spec, you will probably need at least (2) wrenches - one for the small stuff to about 250 in-lbs 1/4"drive (like battery terminals, OPS, etc.) and a bigger 1/2" drive in the 25-250 ft-lbs range (for lug nuts, rear lower shock bolts, etc.). Big torque wrenches are not very reliable at the low end and too big to get in the smaller spaces (like the battery terminals).
Old Apr 1, 2015 | 12:36 AM
6speedsteve's Avatar
6speedsteve
I have a Craftsmen as well have had it for many years and never any issues, back when I purchased mine it was $70. Also have a 3/8" inch pound Craftsmen & a 1/4" Snapon inch pound for small areas.
Old Apr 1, 2015 | 01:14 AM
grantv's Avatar
grantv
Agreed, and same; 2 needed.
Old Apr 1, 2015 | 01:21 AM
Chicago1's Avatar
Chicago1
I have a craft$man that I got for free and a harbor freight that cost 20 dollars. Both read the same after years and years of use and are both clickers. I think the harbor freight for 1/2" and the 3/8" was around the same price 20 bucks each if not one was cheaper then the other. Lifetime warranty on HF tools and can't beat the price. The others are $$$$ screw that noise
Old Apr 1, 2015 | 06:26 AM
DetroitPlac's Avatar
DetroitPlac
For as infrequently as I use a torque wrench, I too bought HF clicker ones (1/4, 3/8, 1/2), and all have been flawless for years. Every now and then I check them against my dad's Snap-ons that he keeps perfectly calibrated and they're always right on.
Old Apr 1, 2015 | 07:30 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
As often as I use them I bought HF this weekend. Reviewed well by Car Craft/Hot Rod and on sale for $11.99 each.
Old Apr 1, 2015 | 07:46 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Craftsman been using one for decades!
Old Apr 1, 2015 | 09:04 AM
RedySetVette's Avatar
RedySetVette
Is 3/8 needed for much? I want to get some to work on car and figured I get: 1/4 in/lbs and 1/2 ft/lbs. Suggestions on 3/8?
Old Apr 1, 2015 | 09:10 AM
DetroitPlac
I use my 3/8 ft/lbs just as much as my 1/2. Like when I installed the headers on my car, the 3/8 worked better (and fit better) for the 10mm bolts.
I honestly rarely use my 1/4 on the car. I mostly use it on my bicycles.
You can buy all 3 from Harbor Freight for less than the price of one from Sears.
Old Apr 1, 2015 | 09:38 AM
jackthelad's Avatar
jackthelad
Another plus for Craftsman and HF. Bought the Craftsman many years ago - pre HF. As I am near an HF store fairly regularly, I get most hand tools there these days.
Best bargain of all was the 12" compound miter saw on special for $139. 4x that for a brand name.
Old Apr 1, 2015 | 09:39 AM
jakecol's Avatar
jakecol
Yup!
Old Apr 1, 2015 | 10:21 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I have one 1/2" and one 3/8" that I use on everything. I also have a dial CDI (snap on owns them) I use for setting up pinion drag.
Old Apr 1, 2015 | 10:47 AM
knewblewkorvette's Avatar
knewblewkorvette
Have you been in my garage? I have the same two plus an additional 1/2" Craftman.
To torque wrench recommendations
Old Apr 1, 2015 | 10:53 AM
dadaroo's Avatar
dadaroo
I too have two Craftsman wrenches for covering the ranges I need.
I CANNOT STRESS TOO MUCH THE NEED TO MAKE SURE THEY ARE ACCURATE!!!!
I have always calibrated mine before use and again over time based on use.
I once bought a torque wrench and calibrated it to find out the it would over torque by 40%.
THIS IS NOT AN APRIL FOOLS JOKE.
Calibrating for me was easy since I used the Nuclear plant cal lab.
You can at least compare yours against someone's else. Or hang weights on the handle.
PS: My bad wrench was a Craftsman which I exchanged.
Old Apr 1, 2015 | 12:03 PM
6speedsteve
Old Apr 2, 2015 | 01:43 PM
jackthelad's Avatar
jackthelad
Received the HF flyer today - 1/2, 3/8/ and 1/4 torque wrenches all down from $29.99 to $9.99. Can't beat it.
