Emergency Break
Old Apr 8, 2015 | 04:14 PM
Trouble Makervette's Avatar
Trouble Makervette
Default Emergency Break
My Emergency Break had no tension to it, car would roll. Had my mechanic tighten it and its still rolling, he says he might be able to get it a little closer so that the rotors don't drag but after that we might have to replace the cable, I am assuming its stretched since its a 99, it is highly possible its original. What do people thing?
Old Apr 8, 2015 | 04:32 PM
stu12dozen's Avatar
stu12dozen
It's brake, not break, it's, not its and think, not thing. Spelling and grammar count.
Take a look at this previous forum post and then you may want to show it to your "mechanic".
https://www.corvetteforum.com/forums...djustment.html
Old Apr 8, 2015 | 05:20 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Go right to post 20 in that thread. That is how you adjust the parking brake in the car. If he did not adjust it properly, it will not hold.
Old Apr 8, 2015 | 06:04 PM
Trouble Makervette
Thanks guys, I think I am heading back to the shop tomorrow so he can check it out.
Old Apr 8, 2015 | 08:53 PM
That is a good link to review. I also have a number of other Word files on adjusting the emergency brakes - if you'd like a copy, PM me your e-mail address and I can forward them to you. Some are too big to make as an attachment here on the forum.
Old Apr 9, 2015 | 12:45 AM
striper's Avatar
striper
You need to check something other than just the emergency brake adjustment. The grease in the handbrake assembly dries out and doesn't allow the brake to hold properly. There was a thread on this a while ago. It turned out my car had the same problem. You need to remove the assembly from the console, clean out the old grease and regrease. Make sure the handle is racheting properly first. If not, this is the problem. Time consuming but easy to fix. You have to remove the passenger seat. Good luck!
Old Apr 9, 2015 | 10:45 AM
Fast one's Avatar
Fast one
Also, Mobil 1 grease won't dry out and cause sticking of the handbrake internal parts like the factory grease.
Old Apr 9, 2015 | 01:06 PM
Trouble Makervette
Vetteman---- Ptucceri@aol.com- Thanks
Old Apr 9, 2015 | 03:59 PM
Trouble Makervette
So I tried the roll back and use the E brake a couple of times , anyhow the ebrake only works in the last knotch all the way up.... and it holds great, the mechanic doesn't think he can bring it any closer or it will rub... I mean its fine but why is it not inguaging sooner?
Old Apr 9, 2015 | 05:21 PM
Fast one's Avatar
Fast one
Did you clean and grease the internal parts of the handle assembly? That's where the slack gets taken up after the shoes are adjusted.
Old Apr 10, 2015 | 09:15 AM
Sigforty's Avatar
Sigforty
You need to go back to post 2 and read the link. That is exactly how my parking brake was. I did the adjustment as outlined in post 20 of the thread link posted earlier. My brake now engages at a 45 degree angle and well before the last notch. Your brake shoes are out of adjustment.
Old Apr 11, 2015 | 01:19 AM
striper's Avatar
striper
I explained your problem in post #6. Go back and read it. It will fix your problem.
Old Apr 15, 2015 | 07:28 PM
Trouble Makervette
I dident think that was 100% the answer, Ill have to do that, now it wont be so tight after I do that right, It will just engage sooner? The seat has to come out or can it be done with it in...
Old Apr 16, 2015 | 01:24 AM
striper's Avatar
striper
This will allow the cable to be pulled up sooner with the handle at approximately 45 degree angle. I can park my car with just the e-brake on a hill. With the handle pulled tight it will not roll. And yes, you must remove the seat or you won't be able to get to the e-brake's mechanism. Removing the seat is easy. There are only four nuts, two in front and two in back of the tracks that hold the seat in. Seat will just lift out, it's not too heavy. It's worth the effort. Before I did mine the brake would hardly hold the car.
To Emergency Break
