Loose Seat Back??
Old Apr 15, 2015 | 11:34 AM
cardozaa's Avatar
cardozaa
Default Loose Seat Back??
So I've seen plenty of posts about the "rocking seat" issue where the seat will move slightly on the seat rails, however I can't find any information on the problem that I am experiencing. The upright portion of my seat has a good bit of back and forth play to it, probably 3" to 4" at the top, and this is especially a nuisance under heavy breaking. Has anyone else experienced this? Could it be a problem with the seat back adjusters? Just curious to see if anyone else has experienced this and found a solution.
Old Apr 15, 2015 | 11:40 AM
dadaroo's Avatar
dadaroo
I am sure this is normal design free play in the seat.
Old Apr 15, 2015 | 02:34 PM
DetroitPlac's Avatar
DetroitPlac
There's a few things that could be at play. There can be an issue with the seat-back adjusters. I didn't really look into it much because I found my issue to be something else.
The mounting tabs for the power seat rails can wear, which causes the rear of the seat bottom to move around. This makes it feel like the seat back is loose. To test, grab the headrest and move the seat back side to side. Watch what moves where the seatback meets the seatbottom. If the seatbottom is moving, it't the mounting tracks that are the issue.
For me, I just swapped my rails to manual rails and haven't looked back. Lighter, insanely rigid (seat doesn't move at all) compared to the power rails, slightly lower (more headroom) and simple to adjust. If you like the power seat rails, there's a kit that fixes it:
http://corvettepartscenter.com/drive...r-kit-1997-04/
Old Apr 15, 2015 | 03:55 PM
cardozaa's Avatar
cardozaa
I'm going to assume this is a joke.
It's pretty clearly the seatback itself that is loose. I have no problems with the bottom of my seat moving as normally seen in the "rocking seat" that is often described.
Old Apr 15, 2015 | 03:57 PM
DetroitPlac
Right. My seat bottom didn't "rock" as people describe it either. It's the rear portion that gets loose and makes the seatback feel loose.
Old Apr 15, 2015 | 04:02 PM
beboggled's Avatar
beboggled
It is part of the normal design. Its mentioned in the GM C5 Z06 video on youtube. I think it was a bad idea, but I do know it was purposely put there for some reason.
Old Apr 15, 2015 | 04:41 PM
cardozaa's Avatar
cardozaa
Wow, you weren't kidding. It's mentioned at about 24:40. Sorry for doubting you!
Still strikes me as an odd "feature".
Old Apr 15, 2015 | 05:53 PM
Daddyrama31's Avatar
Daddyrama31
Make sure your mounting flange is not broken. Common failure and will make your back seat feel unstable.
Old Apr 16, 2015 | 06:47 AM
dadaroo's Avatar
dadaroo
No joke, I have seen half a dozen posts like yours with the same result.
Your free play may be a little more than normal.
Old Apr 16, 2015 | 01:12 PM
frsr06's Avatar
frsr06
https://www.corvetteforum.com/forums...post1588655287
Try this link
Old Apr 16, 2015 | 01:36 PM
MotoJB's Avatar
MotoJB
"Normal" for corvette seats...terrible IMO. I had some special parts machined to eliminate 2/3's of the rocking. They still move a bit. I don't notice it under hard driving now though.
Old Sep 21, 2022 | 01:03 PM
Pronto's Friend's Avatar
Pronto's Friend
Navigator
just watched an episode of Wheeler Dealers on motor trend tv that delt with that very problem and it's a simple fix. Couldn't find the season only that it was episode 4. A 2002 Z06.
Old Sep 21, 2022 | 08:57 PM
The Former's Avatar
The Former
Banned Scam/Spammer
Saw that one! Liked it top to bottom!
Old Sep 23, 2022 | 09:13 AM
oh1vette's Avatar
oh1vette
https://www.corvetteforum.com/forums...seat-back.html
See post # 3 - worked for me....
To Loose Seat Back??
