I'm in the middle of installing a supercharger on my 04 Z06. I want to add a triple pillar pod with guages and was looking for some help on what guages match the factory one the best. I would think someone makes one that match the light color and face but no luck finding one yet. Thanks for the help.
The best I could find was the Autometer Sport Comp 2 that are LED backlit.
I wound up buying their dimmer as well as they were too bright without it.
They're a pure white light and no one makes lighting that's exactly identical to the factory
blue green touch of aqua.
I think they have them in black circumference color as well.
I got the silver ringed ones to match my instrument cluster rings.
I'll post up a better pic when they are lit in the dark later tonight so you can see,
but this 2nd one is a somewhat ok pic
Thanks for the help. I wonder how close the ones with the adjustable color is. The white would be the best option if no one makes a match to the factory color. I'm really surprised no one matches the factory color.
It's also the script style as well.
The ones that you can adjust may not match the C5 cluster.
It depends on how important it is to you.
I let it go since there's 2 things light color and style and the Comp 2 was at least close enough on the style
plus I don't drive a lot at night.
The dimmer made it better, I can set it at the same brightness level so the extra gauges are not super bright white
in relation to the factory cluster.
I've got the Autometer Sport Comp gauges as well but I painted the bezels black to match my interior - I couldn't find these with a black bezel. I had a couple of other requirements in terms of the brand/type/configuration I was looking for so these came close enough as far as the matching appearance to the stock gauges.
This dimmer is 33.00 on ebay if you want to adjust the brightness.
If you're really finicky you might get 2 of them, 1 for each gauge.
I have a cheap 5.00 US available chinese dimmer after this one as the fuel gauge was brighter than the boost
It works good to cut the level a little more but the cheap dimmer does not have the range by itself
to bring the gauges to a low enough level before cutting out.
I just 2 way taped them to the cover under the steering valence on the left
out of the way and easy to get to.
