[Z06] antipowerhop algorithm?
Old Apr 25, 2015 | 09:00 AM
Stroker87's Avatar
Stroker87
Originally Posted by philadd
Judging from one of the links that I was looking through, it seems that someone would be able to tune that out, although I can't be certain. Have you considered (or already installed) other upgrades that will help reduce/eliminate wheel hop?
i'm swapping heads and cam soon hopefully and when I do i'm going to install new engine mounts, I have a DTE brace to install and was going to do the diff mount too. I have upgraded to c6z shock already
Old Apr 29, 2015 | 11:31 AM
Kins13y's Avatar
Kins13y
I have a head/cam 02' and it will wheel hop into the next century if you let it. No reduction in power.
Old Jun 7, 2015 | 09:19 PM
D.Woods's Avatar
D.Woods
Originally Posted by Stroker87
D.Woods I looked in the fuse block under the hood today I have 2 ABS fuse's do i pull both or just one? "if" its just one witch one?
thanks
Super late reply (sorry about that), but it's the Orange 40 amp fuse.
Btw, I never had any of my issue until I put on DR's either....
Old Jun 7, 2015 | 09:54 PM
The Highlander's Avatar
The Highlander
You need a tune to disable this.
Old Jun 8, 2015 | 09:35 AM
Stroker87's Avatar
Stroker87
this was tuned out when the car was dyno'd, pulling the fuses did nothing since this pulls timing
he called it "abuse mode"
