speedometer
Old Apr 20, 2015 | 08:30 PM
DBH-Vette's Avatar
DBH-Vette
Default speedometer
My 98 C-5 speedometer just stopped working. All the other guages work. It's stuck at 200mph. Is there a fuse or relay that needs to be replaced. Does anybody know what happened to it. Has anybody else had this problem. If you know your help and knowledge would be appreciated. Thanks
Old Apr 20, 2015 | 08:44 PM
stu12dozen's Avatar
stu12dozen
Pull the codes and see if anything comes up. It may be a faulty VSS sensor which I believe plugs into the diff. I'm sure someone will correct me if I am wrong.
Old Apr 21, 2015 | 08:39 AM
dadaroo's Avatar
dadaroo
If you have a HUD, does it display correctly.
I have worked on some cases where the needle gets stuck and you just have to access the IPC and give it a nudge with your finger to fix it. It probably did that on an initial startup sweep. If you need to try that here is how to access the IPC.
http://www.vetteessentials.com/instr...zel_howto.html
Old Apr 21, 2015 | 04:50 PM
DBH-Vette's Avatar
DBH-Vette
Default speedometer
Dadaro-thanks for your help- You were right. It just got stuck on start up. It finally popped loose and is working properly now. Thanks again.
Old Apr 22, 2015 | 07:24 AM
dadaroo's Avatar
dadaroo
Easy fix, huh? Didn't even have to do anything. Glad it self healed.
Old Apr 22, 2015 | 07:46 AM
73Corvette's Avatar
73Corvette
Sam... shows up and the Gremlins flee!
To speedometer
