shifter light automatic won't go off
Old Apr 23, 2015 | 07:45 AM
superchargedMagnuson's Avatar
2nd Gear
Default shifter light automatic won't go off
just wondering if anybody could help with a problem I Have A c5 2004 vette with a automatic transmission for some reason the shifter light that illuminates What gear your in ( p-r.n.d.2.1. )does not want to go off regardless of how long I wait Or after the doors being shut engine turned off ......I made sure dimmer switch was in correct position..all other interior lights work as They should.. one day it was fine next day I noticed the problem please help
Old Apr 23, 2015 | 08:30 AM
dadaroo's Avatar
dadaroo
The BCM grounds that circuit to cause the light to illuminate. Either the BCM is the problem or you have a short to ground between the light and the BCM.
I would first try and disconnect the battery for a few minutes and see if you can reboot the BCM to see if that helps.
If you need circuit schematic info let me know.
Old Apr 23, 2015 | 08:52 AM
2nd Gear
Default thanks
thank you .appreciate your time and your knowledge !! ..I have tried to disconnect the battery but no luck ...a schematic would be great ..it would beat walking into this problem blindfolded. again thank you
Old Apr 23, 2015 | 09:04 AM
dadaroo's Avatar
dadaroo
I have mainly gone to provided PDF files for the things like this. PM me with your email and I will provide it to you.
Feel free to ask me any questions.
Do you have the info for accessing the bulb to remove? If not, this link may help.
https://www.corvetteforum.com/forums...indicator.html
To shifter light automatic won't go off
