Dfferent Column Lock ?
--Have SERVICE COLUMN LOCK message on every start, been happening for several months.
--Column does not lock.
--Fuel does not cutoff
--No apparently relevent codes (have several C/H TCS codes and one each RDCM and LDCM H codes, also have permanent seat belt warning light due to apparent failure to sense drivers seat belt is fastened).
--No known work or recall on this system since new.
I don't care that the column does not lock, I just don't want to get stuck if the fuel starts cutting off. My theory is that it is failed in the unlock mode and fuel only cuts off in the locked mode.
Any comments?
Any comments?
My car did it to me today, told me to pull the key and wait 10 seconds. So I did, restarted and still have the column lock message and is locked up but allows the motor to idle. Interested to see what gets posted on here. I do not have the lock either.
All my reading states that the problem could be cleared in your case if you charge the battery up and place it back in the car, which would reset the entire system.
Just ordered C5 LMC5 Module from Compliance Parts as well as the unlock kit since I'm locked up and cant unlock it. My understanding is that this fix is different in that its what the recalls did but a better 'cleaner' fix than the recalls.
I've read a few that stated that GM replaced the column lock motors, as a fix on some of the cars that had the recall fix but were still having the issue.
Sorry I'm not much help, I still don't fully understand how some cars are able to clear the problem by removing the battery and others are having fuel shutoffs even after 'resetting' the systems.
Any comments?
Don't rely on electrical fixes in regards to this matter. Take it to the dealership or whomever and have the lock physically removed from the column. Peace of mind and much more safer while driving our cars, because they 'DO' lock up while driving, ask me !! Of course we all know how dependable electronics are !!
Jus Say'n !!
Any comments?
I installed the Column Lock Bypass in both my 99 FRC and in my current 2001 Z06 before I had an issue. Consequently, I've had no column lock freezes or error messages whatsoever.
I notice the Bypass kits are on sale right now at RPI Designs. There also is the LMC-5 module from Compliance parts that is wired to the BCM that looks easier to install than the Bypass. I suggest obtaining one or the other as soon as possible to eliminate the problem.
The battery is getting to be about 7 years old. I could not find my multimeter to check unloaded voltage so i jumped it from another running car. DIC voltage read 13.3 with engine not running. Seems like that should be enough.
Double checked codes with engine running and after shutoff. No BCM codes whatever (only codes are TCS c1265 HC and c1296 HC). This is the most puzzling part.
Sounds like I should order the LNC5 just to be on the safe side.
Any other input, especially about no codes?
I took the plastic off from under the dash and under the steering column. Super easy, and the locking pin was now visible.
Then I tried a variety of tools. Jigsaw couldn't reach, hacksaw didn't make much progress, Sawzall just vibrated the pin back into the housing instead of cutting it...
So it was time for the grinder. Here you can see it going in for the kill.
A few minutes later, sayonara biotch!
It only took 5 minutes to grind the pin off. I spent more time researching this on the forum than I did working on it. (Though I missed 8VETTE7's last comment about just unplugging it... Oops.)
My tune needs a touch-up anyway, so I'll call MTI on Monday and see if they can raise the fuel cutoff mph at the same time.
It only took 5 minutes to grind the pin off. I spent more time researching this on the forum than i did working on it. (though i missed 8vette7's last comment about just unplugging it... Oops.)
my tune needs a touch-up anyway, so i'll call mti on monday and see if they can raise the fuel cutoff mph at the same time.
Jumped it with car off and key out
Put key in
Got message
Cleared message and read 13.3 volts before starting
So, it seems to me that voltage is adequate and the car wouln't know any difference as to where the voltage is coming from?
With the plastic back on nobody can see it, and now I don't have to worry about paying anyone for mechanical work if it locks up again. (Avoiding big $ for NVA work was my priority.) The car's driving great at the moment and I'll have my tuner increase the fuel cutoff soon.
I'm wondering if battery voltage caused mine too. I had only been doing short trips and it had been sitting for a few days... Hmm.
Post back your results............
The Column Lock Relay is well known for frying internally due to low battery voltage. Here is a pic of a fried CLR:
Ha! Lol very true. Yes I went full redneck and it was glorious...
One of my favorite statements on the forum I've read so far...
you might expect some feed back for your unconventional method for fixing your CL issue... I say, very creative.
I assume at this point you'll have NO problem cutting a hole in your wiper tray if you ever have to replace a bad OPS...
