[Z06] Need Alignment Specs for lowered Z06
Old Aug 14, 2002 | 01:11 PM
MillenniumVette's Avatar
MillenniumVette
Default Need Alignment Specs for lowered Z06
Not sure exactly how much it's lowered but I cut out 1/3 of the bushings in front and used lowering bolts in the rear to level it. Does anyone have the proper spec for this set up?
Thanks!
Old Aug 15, 2002 | 12:56 AM
Johnno's Avatar
Johnno
Default Re: Need Alignment Specs for lowered Z06 (MillenniumVette)
MillenniumVette,
I lowered mine the same way - cut 1/3rd in front and longer bolts in back.
Lowering doesn't require "different" alignment specs. Lowering WILL throw your alignment off a little - hence the need for a re-alignment after lowering. (Drive it first for at least a week or two to let it settle though!)
Did a quick search for Z06 alignment specs on the forum - here's a link:
http://forums.corvetteforum.com/zero...818896#2818896
[Modified by Johnno, 11:04 PM 8/14/2002]
Old Aug 15, 2002 | 12:01 PM
MillenniumVette
Default Re: Need Alignment Specs for lowered Z06 (Johnno)
Johnno,
Thanks, I appreciate it!
To Need Alignment Specs for lowered Z06
