[Z06] external temp reading
Old Aug 14, 2002 | 02:51 PM
edv2122's Avatar
edv2122
Default external temp reading
My Z seems to be reading the outside temp 5 to 6 degress higher then it actuall is. Today it was about 95 and the reading in the car read 100 to 103. My 01 vert's readings seemed to right on. Has anyone experienced this? Is this normal? :crazy:
Old Aug 14, 2002 | 03:10 PM
wt2ga's Avatar
wt2ga
Default Re: external temp reading (edv2122)
Must be "" Global Warming "" :rolleyes:
Old Aug 14, 2002 | 08:13 PM
SAXN8R's Avatar
SAXN8R
I think it is probably right. The sensor is about 6 to 10 inches above the pavement under the front facia. I have compared mine while driving by several banks and such and I am always within a degree or so. If you are comparing it to the local news or weather channels report for the day it could be way off. Those temperatures are usually taken at the airport or the news station which could be miles from you. I have noticed mine reading 102 when the official temp for the day was only 96. I also think that the official temperatures are taken in a shaded area and not direct sunlight which makes a huge difference.
Old Aug 14, 2002 | 08:46 PM
edv2122's Avatar
edv2122
Default Re: external temp reading (SAXN8R)
I am actually comparing to local banks temps, which in my vert was usually righ ton or within a degree. Now it seems to of by 5 to 6 degrees from these same bank temp readings. :rolleyes:
Old Aug 14, 2002 | 09:26 PM
SAXN8R's Avatar
SAXN8R
Well, I guess maybe you do have a problem. I would take it to the dealer if you are in warranty or just get a new sensor. Should be an easy fix.
Old Aug 14, 2002 | 09:42 PM
Rhino21149's Avatar
Rhino21149
Mine reads about 7 degrees warm, regardless of temperature. Haven't had the car in cold (below 60 degree F) weather so I don't know what it does at the other end of the scale, but it is always high.
Old Aug 15, 2002 | 12:52 PM
jerryv's Avatar
jerryv
Mine also reads a few degrees warm ...
Old Aug 15, 2002 | 02:35 PM
vette6799's Avatar
vette6799
St. Jude 15 Year Donor
St. Jude Donor '11 thru '26
Default Re: external temp reading (Jerry Velders)
I have had C5's for almost four years now and the sensor is always reading about 5 degrees high. I would think the air temperature above a blacktop surfaced road is at least that much higher in the summer. I bet that GM engineering has taken that factor into account in their engine programming.
If you have the brass, it would be interesting to take the car out when the road is covered with snow and there is no radiational heating from our mostly black/dark road surfaces. How about an Alaskan winter.
Have you ever noticed the change on a country road when you get to the bottom of a hill late at night with still air. Several degrees cooler.
Old Aug 15, 2002 | 03:21 PM
moparmike's Avatar
moparmike
we as americans need to address the bigger issues of the world..................................
Old Aug 16, 2002 | 12:37 AM
vetthead's Avatar
vetthead
My Z reads about 5 degrees higher when I'm cruising. I just check it while parked in the garage. The car hasn't been started in days :( and the reading matched a thermo mounted on the wall. I think the problem may lie in the location of the sensor. Its got to be pulling heat off the road. I'm curious to see what it does in winter. My C4 seems much more accurate :confused:
Old Aug 16, 2002 | 04:17 PM
jim482's Avatar
jim482
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '03 & '06
Default Re: external temp reading (moparmike)
:confused:
Old Aug 16, 2002 | 04:26 PM
ragvette's Avatar
ragvette
Default Re: external temp reading (jim482)
:confused:
:troll
To external temp reading
