blower motor
Old May 6, 2015 | 12:19 PM
billc80's Avatar
billc80
Default blower motor
I was watching my gutters being cleaned and blower motor started and run about 15 seconds a few minute's later done it again. I unlocked doors and pulled the fuse. ?? 2000 C5. any ideas. ???
Old May 6, 2015 | 01:27 PM
JR-01's Avatar
JR-01
The car was not running and the key turned off?
Old May 6, 2015 | 01:41 PM
billc80's Avatar
billc80
Default blower
yes, had not drove it for a few days. 2 weeks ago I drove it 400 miles to OK. and back, run like a champ, gas mileage 30.3
Old May 6, 2015 | 01:50 PM
JR-01's Avatar
JR-01
This is a good one. I hope someone has an idea.
Old May 6, 2015 | 01:54 PM
Lee DeRaud's Avatar
Lee DeRaud
"Blower motor"...radiator fan or AC/heater?
(Or is there another blower motor I don't know about?)
Old May 6, 2015 | 03:30 PM
billc80's Avatar
billc80
Default blower
A/C-heater
Old May 6, 2015 | 03:33 PM
JR-01's Avatar
JR-01
While you were watching the gutters being cleaned were you drinking any alcoholic beverages?
Old May 6, 2015 | 03:48 PM
Lee DeRaud's Avatar
Lee DeRaud
Follow-up question: "gutters being cleaned"...I assume you're not talking about rain gutters on your house, but something on the car.
Was water getting sprayed around the cowl area?
Old May 6, 2015 | 03:57 PM
billc80's Avatar
billc80
Default blower
house gutters. I can't drink at all. Damn it.
Old May 6, 2015 | 04:51 PM
Lee DeRaud's Avatar
Lee DeRaud
So basically the car was just sitting there undisturbed and the AC blower went on.
I'm thinking some wiring around the fan motor got shorted to ground as a result of some nearby activity. Other than that, I got nuthin'.
Old May 6, 2015 | 05:32 PM
El original's Avatar
El original
Hope I am not the only one confused about what is going on in this thread? To OP suggest you re-write question in a simple manner so we can try and help you.
Old May 6, 2015 | 05:54 PM
Lee DeRaud's Avatar
Lee DeRaud
Nope, pretty much everyone who has posted to it is confused, near as I can tell.
Old May 6, 2015 | 06:15 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
So....the OP was outside watching someone clean the gutters on his house when the A/C blower(fan) in his parked, locked, and not running "vette came on and ran for 15 or so seconds. Then it did it again. He unlocked the car and pulled the fuse to the A/C blower to keep it from turning on by itself again. OP is that correct?
Old May 6, 2015 | 06:19 PM
JR-01's Avatar
JR-01
That's what I understood happened. Were they using a leaf blower to clean gutters? The echo off a wall may have sounded like the blower on the car.
OR.........................
Old May 6, 2015 | 09:41 PM
This is a new one to me. Hope you find what caused the blower motor to come on with the car off.
Old May 7, 2015 | 08:56 AM
dadaroo's Avatar
dadaroo
OK, I need to know whether you have a manual or dual control HVAC head unit.
I think it is the Blower Motor Control Processor. It is powered ALL the time so it's electronics could decide to run the motor.
Based on what system you have I have a couple of other options to consider but I think it is the Processor.
Mr. Sam
Old May 7, 2015 | 10:32 AM
JR-01's Avatar
JR-01
Mr. Sam
Why did GM engineers think it was a good idea to have things like that powered all the time?
To blower motor
Old May 7, 2015 | 10:39 AM
73Corvette's Avatar
73Corvette
Mr. Sam
Damn it Sam... it was just starting to get interesting and you have to come along with some logical explanation...
Old May 7, 2015 | 10:49 AM
billc80's Avatar
billc80
Default blower
Mr. Sam
Manual, put the fuse today seems to be ok car had not been drove for 2 or 3 days.
Old May 7, 2015 | 11:00 AM
dadaroo's Avatar
dadaroo
Good question. What it does is allow many things to be controlled without having to activate relays. If they had a relay for every circuit like this you would need two additional fuse type boxes full of relays.
Also many things are activated or turned off by a simple single wire serial bus command.
Makes perfect sense when trying to reduce the wiring and components in the car.
