Radioflyer's Bi-xenon ACA headlights Available again
Old 10-10-2015, 06:58 PM
  #161
r0bd
r0bd's Avatar
More spots still avail for round 2?
Old 10-10-2015, 07:06 PM
  #162
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Yes. plenty of room so far.
Old 10-11-2015, 04:18 PM
  #163
oharal
oharal's Avatar
What's the contact info for Radioflyer? I don't know if I'll be able to reach anyone on a Sunday afternoon but my hid low beams are inop. Input to ballast has battery voltage when the switch is on but no lights. High beams work though. If I turn the stalk the lights won't come up but if I push for brights, the lights will pop up and close normally if I turn the switch. The only thing I can think of would be bad ballasts? But what are the odds of both being bad? I can't think of a way to test the output...all fuses check out.
Old 10-11-2015, 04:24 PM
  #164
Torch Rot Z
Torch Rot Z's Avatar
I'm installing as we speak. Turns out the HID inputs are reversed. If you look at the wires, the tan output wire for low beam should be connected to the "+" side of ballast input side. If you need further help, PM me.
oharal (10-12-2015)
Old 10-11-2015, 04:32 PM
  #165
oharal
oharal's Avatar
I'll be damned! That did it!
Old 10-11-2015, 11:12 PM
  #166
TXWMH
TXWMH's Avatar
Dang, as a new C5 owner I need these. How long until the second production run is shipped?
Old 10-12-2015, 12:13 AM
  #167
SuperVetteC5
SuperVetteC5's Avatar
Make sure the big plug from the ballast that plugs in to the low beam plug is plugged in backwards, the locking tab should be on the opposite side of what what it is designed for.
Old 10-12-2015, 07:57 AM
  #168
oharal
oharal's Avatar
That's what I had to do...I never ever would have noticed the little molded in markings for +/-...did you guys get lucky and notice that or did you know it was coming somehow?
Old 10-12-2015, 08:05 AM
  #169
Tuscany
Tuscany's Avatar
The instructions said as much.
The following 2 users liked this post by Tuscany:
PreciousChud (10-12-2015), TXWMH (10-12-2015)
Old 10-12-2015, 09:31 AM
  #170
TheRadioFlyer
Supporting Vendor
Checking with supplier to verify when they are to arrive. Once the lights are in stock with the supplier, the new kits should be able to ship in about 2 weeks from time of order.
Old 10-12-2015, 01:37 PM
  #171
Brit dex
Brit dex's Avatar
Originally Posted by theradioflyer
No, they require H1 55w HID bulbs for the projector and a Cree 80w 9005 LED bulb for the high beam.
The good news is that both bulbs will last many many years even if you drive frequently at night.
OK thanks George, and as and when they need replacing are these able to be sourced OK?
Old 10-12-2015, 01:56 PM
  #172
TheRadioFlyer
Supporting Vendor
we have replacements available, but as of yet have not needed them for a bulb exceeding it's lifespan.
Old 10-12-2015, 02:02 PM
  #173
Brit dex
Brit dex's Avatar
Cool, will drop you a mail direct this week on these to cover a couple of things off....
Yet again thanks for helpful replies
Old 10-12-2015, 06:16 PM
  #174
TheRadioFlyer
Supporting Vendor
All kits from Batch 1 shipped!
Thank you for being among my most patient clients!
Old 10-12-2015, 07:14 PM
  #175
PreciousChud
PreciousChud's Avatar
I came in here looking for these. Thanks!
Mine arrived today. I didn't do anything but open the box and take a look but I appreciate the quality you've put into these things.
And all things considered, I don't think the wait time was bad at all, especially once you got everything together.
Thanks again!
Old 10-13-2015, 04:19 PM
  #176
nullpointer
nullpointer's Avatar
Whats next for batch 2? I am assuming you have to order parts?
Old 10-13-2015, 04:55 PM
  #177
The Chev
The Chev's Avatar
I have a couple of questions.
I can figure out what the HIDs do when the high beams are on, but are there LEDs in the high beam location? is that part of the $650 kit?
What is the weight difference between the factory setup and this?
To Radioflyer's Bi-xenon ACA headlights Available again
Old 10-13-2015, 05:29 PM
  #178
Tuscany
Tuscany's Avatar
Yes and yes. Nice, right? George thought of everything.
Not fully sure, but they seemed similar to me. New ones may be a tad lighter (pun intended?).
Old 10-13-2015, 05:50 PM
  #179
TheRadioFlyer
Supporting Vendor
Batch 2 thread here:
https://www.corvetteforum.com/forums...post1590686855
LED are in the high beam location. HID projector pattern changes for high beam to "full beam spread" All of this is included
Our kit is slightly heavier than factory (shipping weight is about 8 lbs) compared to the parts being replaced which are about 3 pounds.
Old 10-13-2015, 05:52 PM
  #180
Sourmug
Sourmug's Avatar
Thanks again!
I completely agree.
Quick Reply: Radioflyer's Bi-xenon ACA headlights Available again
