Well it "was" a nice day
Old May 9, 2015 | 07:33 PM
703's Avatar
703
Default Well it "was" a nice day
Mid / upper 80s so I took the vet and long way into work. So I go on lunch & pick up a few things from another store and when I come back the dreaded happens.
Pull key / wait 10sec and service column lock appear on the dash.
I'm just like well... Damn I should have known this was going to happen, Last time it was this hot outside the same thing happened. Maybe there is a correlation ? I tend to only see the message when it gets really warm out but after it cools down some the messages go away
Luckily I stopped for lunch across the street from my work so I was able to just walk back but the car was stranded until just recently when the temps dropped and messages went away.
Guess I should install the LMC5 that's in my glove compartment
Old May 9, 2015 | 07:50 PM
73Corvette's Avatar
73Corvette
Git r done... before it's too late and it LOCKS for good.
Old May 9, 2015 | 07:57 PM
Hindsight is great, but yes, you should have installed the LMC5 right after you got it. I'd go ahead and get it done.
Old May 9, 2015 | 09:43 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
didn't do much good in the glove box ?????
Old May 9, 2015 | 09:47 PM
tcrote5516's Avatar
tcrote5516
I found the LMC5 easy to install but your glovebox install seems even easier.
Old May 9, 2015 | 09:55 PM
703's Avatar
703
That it was, I mean I had to move a few things around in the glove box to make it fit but overall I think it's one of the easiest installs I've done.
Old May 10, 2015 | 12:03 AM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I have a bypass installed and I still get that message every now and then. I wait 10 seconds re-insert the key & off I go. No big deal.
Old May 10, 2015 | 07:29 AM
rrwirsi's Avatar
rrwirsi
Did you do the Brown Wire installation that is part of the LMC5? If not, see your instruction sheet on page 2 at the bottom titled "Optional LMC5 Modification Procedure". I had the same problem until I did the brown wire step suggested by Richard at Compliance. Suggest calling Richard at Compliance Parts. If you want a copy of the instructions, I can send via email. PM me.
Old May 10, 2015 | 08:27 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Well, I wish I could say I feel for ya but I can't. If you had the fix in your glove box I'm going to say, WHAT THE HELL, MAN....Take the 15 minutes and get that thing installed.
Old May 10, 2015 | 09:15 AM
bjones7131's Avatar
bjones7131
I can't figure what the temp had to do with it but mine seemed to throw the message when it was cold until I did the brown wire mod. Richard said temp had nothing to do with it but go figure.
Old May 10, 2015 | 09:24 AM
radar502's Avatar
radar502
If have one installed DO NOT TURN THE WHEELS WITH THE KEY ON AND THE MOTOR NOT RUNNNG
Old May 10, 2015 | 11:04 AM
3tt3v8P's Avatar
3tt3v8P
And why?
Old May 10, 2015 | 11:26 AM
duramaxsky's Avatar
duramaxsky
Originally Posted by 3tt3v8P
And why?
Yeah why?
Old May 10, 2015 | 01:41 PM
beboggled's Avatar
beboggled
If it happens again before you get it installed, do this:
Turn the key to on, see service column lock message, leave key in position, disconnect and reconnect battery, start car (without turning key back to off), and drive away.
I figured this out when it happened to me. Ordered an LMC5 when I got home, but had to use this trick a few times until it arrived as the C5 is my daily.
Old May 10, 2015 | 02:11 PM
Stingray Wes's Avatar
Stingray Wes
it's pretty easy to install.....it took me probably 30 minutes. Comes with great instructions.
Old May 10, 2015 | 02:17 PM
radar502's Avatar
radar502
And why?
Sorry you will get the ( Someone is trying to steel you Corvette deal and after a week it might go off might not ) Why do I know this well I was working on the 04 with the key on motor not running and BAM I got the O-No you didn't turn the wheel YEP and yes I got the MC-5 whatever deal witch is easy as heck to install. A friend locked out for 4-hrs in a 98 years back ..
To Well it "was" a nice day
