Hey everyone so I posted a thread a couple days ago about getting the pull key wait 10sec / service steering column message.
So today I went to install the lmc5 that has been sitting in my glove compartment and I ran into this The previous owner hardwired a radar detector so that's what I'm thinking this is but I can't say for sure. Any suggestions on where to go from here ?
The orange yellow and black wires are a key on accessory harness under the dash.. could have been anything but most likely a radar detector. Not sure on the two purple wires
Hinson in B-Ham Alabama sells them give them a call they helped me on my install nice people.. .Just an FYI after the install do not turn the wheel with the key on and the motor off you will get the Pull key deal ..
I would proabably just remove the previous owners wiring and procede with the LMC5 install or just leave it and install the LMC5, it should not interfere with install. Just to make sure contact Richard at compliance (855-565-8388) he will be glad to walk U through it or advise U on what U should do. Any chance U can contact previous owner and make sure that is what the wiring is for. Good luck
If so that is the factory recall mod referred to as the "purple wire and relay mod". Yes that crappy looking wiring job came from parts GM sent to dealers to install.
Back when there was no LMC5 and the CLB was the ONLY game in town for column lock symptom relief you needed to bypass that relay on 99 and 2000 manual trans cars to insure that the CLB would work every time.
NOT necessary to touch that wiring if you are installing an LMC5 as best I understand.
Dude, you pulled that one out of the archives 09 wish I had that good of a memory! Nice!
You are correct it's a manual 2000.
So I should be ok to remove it and install the lmc5 as normal ?
