Engine Idle Smoothness Question
Old May 11, 2015 | 11:38 AM
VettesGoneWild's Avatar
VettesGoneWild
Default Engine Idle Smoothness Question
Should I expect as normal an occasional roughness (minor) during idle as the nature of the beast or should it be completely steady as she goes similar to my non-Vette daily drivers? Within the last year I have replaced fuel filter, plugs and wires, battery and had throttle body cleaned. I also use Techron every other tank full. If this is not normal what may be potential areas in need of attention? Thanks for any advice!
Old May 11, 2015 | 11:50 AM
Macleod52's Avatar
Macleod52
I would like to know as well. I know my Vette has a slight roughness too it. I have new plugs, wires, cleaned the MAF and TB and use seafoam on the top end.
Old May 11, 2015 | 12:45 PM
JR-01's Avatar
JR-01
My '01 idles rough for a few seconds when first started cold, but is smooth as silk after that.
Diagnostics may be able to change idle mixture Don't know.
Old May 11, 2015 | 12:53 PM
73Corvette's Avatar
73Corvette
04 6spd 33k Vararam B2 TI exhaust... Idles a little rough intermittently, nothing consistent about it... just seems to on occasion take drink or inhale something it doesn't care for and shivers... then smooths back out.
Old May 11, 2015 | 02:59 PM
grantv's Avatar
grantv
04Z, idles pretty rough full time, no complaints.
Old May 11, 2015 | 04:06 PM
El original's Avatar
El original
My '03 idles smoooooth! Sometimes after some spirited driving it idles rough but soon smooth out.
Old May 11, 2015 | 04:47 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
99 coupe with 59,000 idles between rough and smooth if that makes any sense ????????????? just know I don't lose sleep over it !!!!!!
Old May 11, 2015 | 05:24 PM
SG Lou's Avatar
SG Lou
Mine did the same up until I replaced both forward O2 sensors...idles smooth as silk
Old May 11, 2015 | 05:26 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Mine are new, no change !!!!!
Old May 11, 2015 | 07:09 PM
1Willy1's Avatar
1Willy1
mine idles smooth with a slight cough now and again, also if I stare closely at the rpm gauge it fluctuates within about 100 rpm +/- on start ups.
Id say , based on everything else ive seen on the vette, that this is normal.
This is not a highly refined , highly engineered car, and all of this goes with the territory.
Nothing to worry about in my opinion.
Old May 11, 2015 | 07:10 PM
JR-01's Avatar
JR-01
It was supposed to be. GMs best effort.
Old May 11, 2015 | 07:41 PM
kennedy759's Avatar
kennedy759
I notice a slight rough idle when sitting at the drive thru at the bank on my 97, new plugs and wires, 95k miles
Old May 11, 2015 | 09:17 PM
I have had three C5s and each one has had a slight roughness at idle. IMO, it is just the nature of the beast.
Old May 11, 2015 | 09:26 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Just put a cam in it and then you will be happy,,,,, Oh ya man I have a cam in it dude !!!!!!!!!!!!!!!
Old May 11, 2015 | 09:47 PM
Koufax's Avatar
Koufax
My '04 idles a little rough. Purrs like a pussycat when she's in gear. She's obviously much happier in motion than sitting still. So am I, so we're a good match.
Old May 11, 2015 | 09:50 PM
Mistrezz 06's Avatar
Mistrezz 06
My 04 Z idles a bit rough but I like it, it's as if she ready to take off running. ������
To Engine Idle Smoothness Question
