Gear shift indicator
Old May 12, 2015 | 12:08 PM
xzo124's Avatar
xzo124
Default Gear shift indicator
How tough of a job is it to fix /replace gear shift indicator and light in gear shift ??? light is out and indicator is in 1st gear at all times ...xzo
Old May 12, 2015 | 12:21 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
You have to remove the center console and glove box. Light is easy to fix. It's a 194 bulb. There is no replacement part for the indicator.
Old May 12, 2015 | 09:08 PM
No reason to remove the glove box that I know of. Simply removing the center console (has the center arm rest attached to the top of it) as well as the bezel surrounding the radio/HVAC controls will give you access to the shifter components.
Here are a couple of Word files that discuss replacing the light bulb as well as fixing a broken indicator - if that is what is wrong with your car.
File Type: doc
Old May 13, 2015 | 11:43 AM
Ghost Vette's Avatar
Ghost Vette
Default Shifter indicator
I see often on Flea-bay replacements for the indicator and lens. Cost is around $25 if I remember correctly. I picked up one about a year ago on there. Otherwise I don't know of any other place to get replacements..
Old May 13, 2015 | 10:10 PM
rx4arx's Avatar
rx4arx
Default Saw this a while back. useful for you?
http://www.corvettemods.com/C5-Corve...b_p_11312.html
Old May 13, 2015 | 11:36 PM
AC1074's Avatar
AC1074
Zip corvette sells the gear shift indicator as well HERE
Now the actual replacement I have researched is a chore. My understanding is you have to disassemble the gear shift control box to get to it.
Old May 14, 2015 | 06:46 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
i didn't mean the one on the passenger side. i should have said radio bezel and arm rest.
Old May 14, 2015 | 06:47 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
well now i know where to get one. i have taken the assembly apart trying to repair mine before. not a real chore to do.
To Gear shift indicator
