Brake upgrade?
Old May 29, 2015 | 09:34 PM
Skrilla's Avatar
Skrilla
Default Brake upgrade?
Looking to supercharge my c5 convertible within a year and always would like to upgrade the brakes . What is the best bang for the buck upgrade?
Old May 29, 2015 | 09:46 PM
olbear1962's Avatar
olbear1962
C6Z06 brakes, an easy DIY project
Old May 29, 2015 | 09:50 PM
Stealth02's Avatar
Stealth02
c
Old May 30, 2015 | 10:14 AM
jackthelad's Avatar
jackthelad
...IF the OP already has front wheels that will accommodate those brakes. Got to be 18" fronts, and even so, spacers may be needed.
Question I would ask - how far do you want to go? Would better rotors and pads do the job? I have been running Baer rotors and Hawk pads for years, and find for "fast road" driving, they are fine.
Old May 30, 2015 | 11:44 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You can also do the C6 Z51 rotors and brackets from Gene Culley at Cultrag:
http://www.cultragfactoryparts.com/
These are what I use on my C5 with 734 RWHP and they work great!
Thanks,Matt
Old May 30, 2015 | 02:40 PM
SuperTom's Avatar
SuperTom
Thanks,Matt
can you help with part #'s?
Old May 30, 2015 | 03:51 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
None of those "upgrades" will make the Corvette stop any shorter.
The stock system already operates the ABS.
Old May 30, 2015 | 04:54 PM
racebum's Avatar
racebum
on what tire? with what pad? if you come down hard from 180mph i can promise you the stock pads will not engage the abs, the fade will scare the hell out of you though
brake upgrades make a lot of sense if someone needs either more clamping force, more surface area or a larger heatsink for repeated stops? the c6z calipers have a nearly identical clamping force to the c5 calipers. bigger heatsinks yes but be aware of what you're buying
if this is just a street car a person could probably get by using a good street pad like the hawk hp+ with stock rotors and calipers and be just fine. that pad will haul you down from some fairly high speeds without fade. they just get in trouble if you do it over and over in short order.
another point that moving to a good 4-6 piston monobloc caliper and larger rotor give you is the ability to put out more friction via that higher clamping force and increased swept area without having to use fairly dusty pads like the hp+
you're starting at $2500 for a standard brembo 4piston big brake kit for just the front. likely double that for all 4 corners, more if you go larger or 6 piston.
Old May 30, 2015 | 06:32 PM
Skrilla's Avatar
Skrilla
Thanks for the input ,so are the c5 z06 brakes any different ?
Old May 30, 2015 | 06:50 PM
rjwz28's Avatar
rjwz28
No, they're not... just the pads
If you're looking for an aftermarket 6-piston caliper, this is the best bang you can get for your buck:
http://www.tceperformanceproducts.co...te-c5/kits-35/
Hit up Todd TCE on here for more info on those
Old May 30, 2015 | 07:05 PM
skull's Avatar
skull
I upgraded to c6z brakes for like 1200 bucks. so worth it. and just run 18x10.5 c5z on all 4 corners
Old May 30, 2015 | 07:35 PM
rjwz28's Avatar
rjwz28
Where did you get all the parts for that swap for $1200??? It usually costs about a grand more than that
Old May 30, 2015 | 08:12 PM
skull's Avatar
skull
750 on calipers I got off here.
350 for new rotors from gm
70 on some use stock pads in the autox section.
you need the braided lines from summit that are 150 but it is a recommended upgrade for brkes
Old May 30, 2015 | 09:26 PM
Socko's Avatar
Socko
Just buy some wilwoods. fsl6r or fnsl6r with the stock rotors is the hot setup on stock c5z wheels they clear with 12.8 or 13.4" rotors. TCE or KNS sell kits for stock rotor setups. Rear brakes are MEH, fronts are key if you are looking for bang for the buck.
Old May 30, 2015 | 10:49 PM
madmatt9471
I'll get the numbers for you in the morning.
Thanks, Matt
Old May 30, 2015 | 10:55 PM
Skrilla's Avatar
Skrilla
Ok so I'll pass ok buying a z06 set up lol
Old May 31, 2015 | 11:19 AM
madmatt9471
Here you go: The factory C5 and C6 "Base" model brakes are the same (Calipers, brackets and rotors) so this kit upgrades both the C5 and C6 Base brakes to the C6 Z51 brakes (rotors and Brackets) you will use your "STOCK" Calipers
http://www.cultragfactoryparts.com/c...c6-z51-brakes/
Thanks,Matt
To Brake upgrade?
Old May 31, 2015 | 11:25 AM
madmatt9471
Here is more information on sizing:
Corvette Museum website says the non-Z51 front rotors are 12.8 in. in dia. and are 1.26 in. thick, while the rear rotors are 12.0 in. in dia. and 1.0 in. thick.
The Z51 front rotors are 13.4 in. in dia. and are 1.26 in. thick, while the rear rotors are 13.0 in. in dia. and 1.0 in. thick.
Thanks,Matt
Old May 31, 2015 | 11:46 AM
Cedarberry's Avatar
Cedarberry
Just watch the C6 section, I bought 08 C6Z06 calipers and stock rotors from a member for 860.00, stainless lines for 100.00, all four corners.
Old May 31, 2015 | 12:04 PM
Sox-Fan's Avatar
Sox-Fan
Thanks,Matt
If you are going that route (a good way to go)...
FWIW c6 z51 calipers are a big upgrade of c5 calipers. They are very cheap and bolt right straight on. They are a different manufacturer than the c5 calipers and are far stronger. They won't spread over time as a C5 caliper will if you really really use them hard. $106.00 each on Amazon.
