Rear axle nuts?
Old Jun 7, 2015 | 12:38 AM
R1 Rider's Avatar
R1 Rider
Default Rear axle nuts?
Seems to be a fairly common problem for the splines on the rear axles to get dry, dirty, rusty , or the axle nut itself to losing up and cause a clicking sound at low speed. My question is, what's the correct procedure to remedy this?
Do I just clean the axle splines or clean/lube them? Do I use loc tite or not? Do I re torque to 118 or 160? (Have read both)
Old Jun 7, 2015 | 02:52 AM
Cliff8928's Avatar
Cliff8928
The torque is 118 lb ft (160 N·m)
If it were coming loose I would just use a new one since they are lock nuts. I picked a couple up at AutoZone for around $5/ea.
Old Jun 7, 2015 | 08:48 AM
R1 Rider's Avatar
R1 Rider
I may do that since I have to go there to get a 33mm socket anyway
Old Jun 7, 2015 | 12:26 PM
Kehraus's Avatar
Kehraus
Be sure to check for possible damage to the half shafts. The nut can also strip the threads. I broke a half shaft that way. I had the hub replaced at the same time because it was not perfect.
Old Jun 7, 2015 | 12:30 PM
1blkc4's Avatar
1blkc4
mine did the samething grease the splines i used a needle attached too my grease gun
Old Jun 7, 2015 | 05:40 PM
R1 Rider's Avatar
R1 Rider
Guess they're not loose, breaker bar and a jack handle wouldn't break them lose
Old Jun 7, 2015 | 07:53 PM
c4cruiser's Avatar
c4cruiser
Get some PB Blaster and spray the nut and threads. Let them sit overnight and spray again. You will probably need an impact wrench to get the nuts loose. If you don't have an air compressor for a air impact wrence, you should be able to rent an electric version or go to Harbor Freight and buy their electric impact wrench.
Old Jun 7, 2015 | 09:47 PM
R1 Rider's Avatar
R1 Rider
I had let pb blaster sit on it all night, no luck, gonna take some air power!
Old Jun 10, 2015 | 09:26 AM
2FAS4UU's Avatar
2FAS4UU
Yup, same here, it even sheared the 1/2" lug off my Craftsman breaker bar. PB and maybe some heat as well !! Jus Say'n
Old Jun 10, 2015 | 12:46 PM
bad man Barry White's Avatar
bad man Barry White
St. Jude Donor '16
Are they reverse thread?
Old Jun 11, 2015 | 02:40 AM
Cliff8928's Avatar
Cliff8928
Nope, standard right-hand thread.
Old Jun 11, 2015 | 06:55 AM
guido7834's Avatar
guido7834
I was able to get mine off with a breaker bar when I did it a few years ago. Greased the splines, reused the nuts and no problems or noise since.
To Rear axle nuts?
