What is this thing?
Old Jun 7, 2015 | 09:23 PM
El original's Avatar
El original
Default What is this thing?
I post this question every 6 months or so and never have had anyone tell me what this...or will I have to post in 6 months again!?
Old Jun 7, 2015 | 10:18 PM
StingrayRebel's Avatar
StingrayRebel
that looks like the spot where the cradle stud goes through the frame, however that does not look like the factory stud... maybe it was replaced before you bought the car??
Old Jun 7, 2015 | 10:19 PM
That is a bolt and retainer clip that holds the front cross member to the frame rail. There are two on each side in the front and two in the back on each side holding the rear cross member to the frame. The ones on my car looks exactly the same as in your pic.
This was found on page 8-1444 of Volume 3 in my 2003 Factory Service Manual.
Old Jun 7, 2015 | 10:32 PM
El original
So there is a bolt under the cover that secures the cross member to the frame rail, is that correct? Wonder why all the hardware? Can I take the clip off to inspect without any issues? You a are right on the count, there are four of them.
Old Jun 7, 2015 | 10:34 PM
StingrayRebel
weird, my car as well as all the others I can remember seeing have different looking studs like in the pic below
Old Jun 7, 2015 | 10:38 PM
StingrayRebel
it is a long stud that goes completely through the frame then the cradle fits over these studs then nuts screwed onto the studs to secure the cradle to the frame... the reason it is like that is so that the studs can easily be replaced if you happen to strip them out while installing or removing the cradle nuts
Old Jun 7, 2015 | 10:43 PM
El original
Right on guy's...thankyou for answering one of my Corvette mystery (for me) parts!! I will be back in 6 months with another question. Keep posted, lol. Greetings, Rob
To What is this thing?
