ABS/Traction Control
Old Jun 10, 2015 | 05:55 PM
DBH-Vette's Avatar
DBH-Vette
Default ABS/Traction Control
I've been reading all the replies and tried them. I cleaned all 4 grounds under the hood. The one below the master cylinder was really rusted. Had a real fight getting down there and breaking it loose. I had the battery disconnected to replace the passenger side actuator. I cleaned the ground under the battery at the same time. Today I took it for a drive and the abs/traction was off but as soon as I hit a bump it came back on. I stopped at the store and it did the same thing. It was off and as soon as I hit a bump. Any ideas about the possibilities causing this would be greatly appreciated. As for the actuator I'm still getting a code for a short and now it's putting out hot air on the passenger side instead of cold air. Thank you in advance for any help.
Old Jun 10, 2015 | 06:16 PM
DBH-Vette's Avatar
DBH-Vette
Sorry about that. I noticed that after I posted. It's a 98 coupe lingenfelter 383 stroker. I believed it wasn't one of the first one's built in 98
Old Jun 10, 2015 | 06:40 PM
DBH-Vette's Avatar
DBH-Vette
About a month ago the abs/traction was always on and now it is off when I start the car and begin driving then comes on when I hit a bump and stays on until I restart the car. Then it happens all over again. I've wondered about it being ebcm which is under the alternator but I'm told they're very expensive and can't be repaired.
To ABS/Traction Control
