So what's this noise?
Old Jun 10, 2015 | 11:06 PM
gulfstrings's Avatar
gulfstrings
Default So what's this noise?
Just got my car back from dealer - all new fluids/seals in the rear where needed - ready to go. After about 300 miles on the freeway I pull in for a pit stop and at parking lot speeds near the pumps I hear what seems to be some kind of whistling noise. Can't really tell where it's coming from.
It's consistent.
Not affected by engine RPM, in or out of gear, AC on or off.
I can hear it in the cabin but haven't been able to pick it up outside the car.
All readings are normal. Car's running fine.
Any ideas appreciated. We're a long way from home ...
Old Jun 10, 2015 | 11:17 PM
El original's Avatar
El original
Sounds like the air pump(smog pump)...mine does it all the time, would not worry about it. Pumps air into exhaust to lessen the pollution readout at tailpipe. The sound is a whistle sound drivers side front of engine. Safe journey.
Old Jun 10, 2015 | 11:32 PM
gulfstrings
Smog pump it is. I would have accepted muffler bearing just to clear the concern and keep on traveling.
It's honest support like this that makes our forum the best.
Thanks, really appreciated.
Old Jun 11, 2015 | 12:07 AM
Trios's Avatar
Trios
Hate to break it to you since you were so happy with the smog pump idea, but the AIR pump only runs for a few seconds on a cold start.
Old Jun 11, 2015 | 12:26 AM
grantv's Avatar
grantv
Yep, unless there's something wrong it's only on at cold start. Maybe a vacuum leak?
Old Jun 11, 2015 | 06:40 AM
gulfstrings
I think El Original nailed it. Believe it is the whistle-like sound I hear when first starting the car that, as Trios says, is supposed to run for only a few seconds.
We're in Birmingham and planning to visit Barber Motorsports Park museums today but think we'll visit Barber Chevrolet first.
In case it really is a "muffler bearing ..."
Old Jun 11, 2015 | 06:49 AM
gulfstrings
Thanks for the input. Believe it may be the air pump malfunctioning. Thought about vacuum but (might be wrong here) assumed a vacuum leak that pronounced would change with the RPM of the engine and cause it to run rough. 'Course this is from someone who hasn't wrenched his own car since my '56 Chevy.
Awesome forum. Believe it is by definition a place where the ideas of each come together for the benefit of all.
Unless your name is Ceasar.
To So what's this noise?
