To make a long story short... I basically need to find a way to keep my headlights popped at shows to advertise our product. Is there a way to keep them up without having the switch on?
The only way I can suggest that might work is to once the headlights are up, is to maybe pull the fuse that operates them and then turn the lights off or install a separate switch. I think someone that is more familiar with the electronics on C5's will chime in with a absolute way. Good luck, what is the product your trying to display ?
As 8VETTE7 suggested will work, just will take some time cranking them up.
no as of now were mainly doing HID setups, the LEDs just arent reliable enough yet... however we are doing LED switchback rings and RGB Color changing rings and Demon eyes in them. Also doing switchback corner markers and all that good stuff. Lotta crazy c6 stuff as well.
