Traction control problem
Old Jul 5, 2015 | 09:57 AM
wjr1575's Avatar
wjr1575
Default Traction control problem
I just totaled by 2008 C6 and the insurance company didn't give enough money to replace so I bought a 2004 C5. The only problem is that the traction control system goes off for no reason when I am driving. When this happens I feel a tug on the wheel and the Traction control light goes off as if I had spun out even though I didn't. This seems dangerous and I would like to get fixed. For now, I drive with the Traction control off so that this doesn't happen. Does anyone know what needs to be replaced to fix this issue?
Old Jul 5, 2015 | 08:37 PM
coia96vette's Avatar
coia96vette
Sounds the SWPS going out. Bet you get the C1287 and/or C1288 codes when you pull them. It may take a while for them to show up though. Same thing happened to my '04 and the SWPS was the culprit. Not to bad to replace. Costs about $65 for the sensor and take about 2.5 to 3 hours to replace.
Old Sep 27, 2015 | 11:01 AM
wjr1575's Avatar
wjr1575
Default codes to find out how to fix traction control
Here is the information about my codes.
The front tire size is M+S 245/45zr17, rear tire size is P275/40zr18
Codes are: AO-LDCM: B2264H,U1255H,U1064H,U1096H,B2204H,B2282 H,B2284H,B2262H
A6-SCM:B2605H,B2860H
BO-RFA:C2115HC
60-IPC:B0516H,U1160H
A1-RDCM: B2205H,B2283H,B2285H,U1255H,U1064H,U1016 H,U1096H
Any help would be greatly appreciated.
Old Sep 27, 2015 | 03:03 PM
rrwirsi's Avatar
rrwirsi
Please explain what the acronym SWPS stands for. Thank you.
Old Sep 27, 2015 | 03:10 PM
SilverC54me's Avatar
SilverC54me
SWPS - steering wheel position sensor.
This is about a 2hr DIY job to replace the sensor. The sreering column needs to come out to replace it.
OP, if you are in So Call PM me to for help in verifying and replacing the sensor.
Gary
Old Sep 27, 2015 | 03:14 PM
rrwirsi's Avatar
rrwirsi
Gary
Thank you Gary. I will add this info to my list of abbreviations that are used on this forum.
Ron
Old Sep 27, 2015 | 03:36 PM
Marine One's Avatar
Marine One
Another vote for a bad SWPS. Mine was doing the same thing. Before that it would just disengage the cruise control for no reason. It never did throw a code.
To Traction control problem
