Corvette is flashing all error codes
Old Jul 13, 2015 | 08:45 AM
gilbroyer's Avatar
gilbroyer
Default Corvette is flashing all error codes
So I went to start up my 2002 C5 convertible this morning and the dash was spitting out all the error codes – service traction control, service abs, service tire pressure monitor, etc.
Any thoughts what I should do? This issue has happened in the past (rarely), but usually when I turn the car off and on it goes away, however I tried to do this multiple times this morning and could not get the flashing of the codes to go away. Any help would be appreciated the car has 31K miles.
Old Jul 13, 2015 | 08:53 AM
Make sure your battery is good. If it is weak, it is not uncommon for the car to set off all kinds of warning messages.
Old Jul 13, 2015 | 09:00 AM
calvins's Avatar
calvins
Oldtimer
And the dash gauge is *not* an indication of battery condition. It must be measured across the terminals with the negative disconnected.
Old Jul 13, 2015 | 10:39 AM
JR-01's Avatar
JR-01
First thing to check is battery. It should be 100% and make sure connections are good. Has it been sitting for awhile? Once you make sure battery is at full charge and connections are good then you can work from there.
Old Jul 13, 2015 | 12:54 PM
SuperTom's Avatar
SuperTom
Yep battery is the first thing to check. After that look at your ground locations for rust ECT. Anything more than that is gonna start to cost $$$
Old Jul 13, 2015 | 01:26 PM
SuperTom's Avatar
SuperTom
Originally Posted by 8VETTE7
I would disagree with that. If the battery is NOT the cause then the info at the link in post # 4 is an easy DIY possibility.
My point was to try the easy stuff
first before shelling out money
Old Jul 13, 2015 | 01:37 PM
El original's Avatar
El original
I would disconnect the battery for 5 min. reconnect and see if that is a fix. Sounds like some electronics are tripping all over themselves so try a re boot.
Old Jul 13, 2015 | 02:01 PM
Daddyrama31's Avatar
Daddyrama31
Battery!!!!!!!
To Corvette is flashing all error codes
