Best low beam alternative?
Old Jul 13, 2015 | 09:51 AM
motomanvette's Avatar
motomanvette
Default Best low beam alternative?
Looking to upgrade my low beams. Thinking that the Silverstone Ultras available at WalMart might be a good choice. Any thoughts?
Old Jul 13, 2015 | 11:07 AM
Radicaltimes's Avatar
Radicaltimes
I have the Sylvania SilverStar Ultras in my headlights It is a small improvement. I used them in my Accord and there was a lot of improvement. They are a higher amp bulb so the life is shorter. In my Accord they were on all the time and lasted two years. In the Vette they should last a lot longer
Old Jul 13, 2015 | 11:21 AM
Torch Rot Z's Avatar
Torch Rot Z
For me, the factory housing does not let you improve much regardless of which bulb you go for. Doesn't matter how much output you have if the light is just getting scattered. Proper aiming is going to give you the biggest improvment IMO without switching to a projector setup. My lights were useless at night until I aimed them correctly.
Old Jul 13, 2015 | 11:30 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Here's what I went with...
> Philips 893 CrystalVision driving light bulbs
> PIAA Xtreme White Plus headlight bulbs
...these are a noticeable but modest improvement over OEM. Since I don't drive the Vette much at night, these are good enough for me. If I did a lot of night driving, I would spend the money and go with RadioFlyer.
Old Jul 13, 2015 | 12:56 PM
Stealth02's Avatar
Stealth02
I'm attaching a YouTube link on the lowbeam mod. If you want the most light output available without having to go to projectors or HID bulbs pick up a set of 9011 HIR bulbs and follow this procedure. Major improvement over the stock bulbs. You can up the light output even more by adding the 4 on relay harness, allowing rhe lowbeams to stay on when high beams are on. Hope this helps. I personally am tired of dealing with HID projector lights and the ballast failing. My coupe fogs, 01 vert ACA lights and my Avalanche all have ballast issues and lights not working properly. Retroing all three to the 9011 HIR bulbs. Even the fog lights. Goodbye ballsts.
Old Jul 13, 2015 | 01:00 PM
StingrayRebel's Avatar
StingrayRebel
if you want to keep the pop up style I would recommend trying to find some aca's with an hid kit... the stock housings suck so it really doesn't matter what bulb you put in it... with an actual projector and hid you probably won't need your high beams anymore
Old Jul 13, 2015 | 01:08 PM
caroutisine's Avatar
caroutisine
I did the same and have to agree with some of the other comments about the Silverstars. A modest improvement, but worth it as it's not too expensive and easy to do.
Old Jul 13, 2015 | 01:17 PM
CorvetteKid82's Avatar
CorvetteKid82
I swear by Ultra's in my other vehicles, but they do not even come close to comparing with true HID setups and a proper projector housing. I would shop around if you go with the Silverstars.. Wal-Mart's price can be beat online. I would love to pull the trigger on some of RadioFlyer's work but I don't currently have the funds... I did just buy the relay for the 4 lights to operate with the high beams from him though.
Old Jul 13, 2015 | 01:30 PM
StingrayRebel
I have about $325 invested in my aca setup, $275 for the housings when they were available and a $50 55w hid kit from ddm tuning and the light output is great, even with the projector they come with... I don't think the radioflyer setup could produce more output that was worth the $300 price difference, however aca's are harder to come by nowadays so that might be the only way to go if you want those housings
Old Jul 13, 2015 | 01:40 PM
jackthelad's Avatar
jackthelad
You can get HIR bulbs from Candlepower - Google them. Good to deal with.
Old Jul 13, 2015 | 01:51 PM
Stealth02's Avatar
Stealth02
The 9011HIR bulbs are brighter than any of the silver star bulbs made. Granted the clear ACA housings would better the light output. But if he is just wanting to stay with his stock housings and just do a bulb upgrade the 9011HIR's will give him the most light output. I am meeting up with a guy that has the radioflyer V3 setup and anorher that has the ACA HID projectors and am going to compare the light output between the two with the 9011HIR lowbeam setup in my Breathless lights.
Old Jul 13, 2015 | 02:09 PM
CorvetteKid82
The RadioFlyer ones come with a Bi-Xenon setup. This is the same technology used in upscale cars and have a mechanical shield that raises to allow high and low beam operation from the same bulb. I do not think the ACA's do that without being modified.
I'm sure that either setup produces much more light than the stock housings and would be happy with either, but RadioFlyer's quality has really impressed me so far.
Old Jul 13, 2015 | 02:11 PM
2FAS4UU's Avatar
2FAS4UU
After trying several bulb types and wattage from different manufacturers, the largest improvement I experienced is what is stated here about 9011 HIR bulbs. Although, even when aimed properly the light is still scattered somewhat and the color is still that sucky yellowish tint, but brighter. As suggested by Stealth02, ACA's w/HID will be the best bang for the buck other than buying quality lights such as Sun Guns, Radioflyers !! Jus Say'n !!
Old Jul 13, 2015 | 06:08 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Don't waste your money on Silver Star's.
Old Jul 13, 2015 | 06:17 PM
StingrayRebel
I understand what they do I'm just saying that the aca's work so well already that I don't think the others could be $300 better... I bought his light cannons before the aca's and was not impressed at all for the price I paid... the aca's worked much better for half the price... this was years ago so maybe he has improved them since the ones I bought
Old Jul 13, 2015 | 10:46 PM
CorvetteKid82
Duly noted. I will take that into consideration when I pull the trigger. Good info!
Old Jul 13, 2015 | 11:29 PM
ALLEGRO's Avatar
ALLEGRO
Do a search and do the 9005 conversion.
This puts a "high beam" bulb in your "low beam" spot. Added wattage with little mod on the BULB and without any issues.
I did this with SilverStars and the difference is amazing.
To Best low beam alternative?
Old Jul 14, 2015 | 02:23 AM
john8642's Avatar
john8642
Another vote for the 9011/9012 HIR bulbs. Made a noticable difference over the stock. For better high beam performance, you can also get the 4-HI harness that keeps the low beams on when you switch to high beams. I did both for about $100.
Old Jul 14, 2015 | 06:44 PM
motomanvette
So i just buy the 9005s and plugged em in to my low beam outlets?
Old Jul 14, 2015 | 07:12 PM
Deadpool87's Avatar
Deadpool87
Here you go plug and play HIDS. Just ordered a set for my c5 zo6 will have them tomorrow. So I will let you know how they look. http://www.hidextra.com/9006-10000k-hid-kit/
