Does the DIC reading voltage--is that the voltage going to the battery? Like mine reads 13.5-13.9 most of the time-turning on the A/C drops it down to 13.2-13.5-
Mine's generally about 14.2 on start up and I really don't look at it afterwards but I wouldn't think you're in a problem range at all with the AC on.
You might have your battery checked if you're concerned . . .just like Vegas we run AC out here about 9 months out of the year, so battery replacement every 3 years or so is pretty common.
EDIT: Saturday afternoon--It's 117 here this afternoon so the AC's running full blast . . . .mine's reading right where you are-- 13.2.
The DIC reading is typically lower than the actual voltage at the battery since the reading is via the ignition electrical switch contacts. You can easily read 1/2 volt lower and more with a problem switch.
The DIC reads voltage at the battery. A fully charged battery at rest should read about 12.6 volts using a multimeter. When the car is running, the voltage should be a little higher because the car's systems require power from the battery and the alternator will supply power to the battery to keep it charged. If your battery is fully charged, you may see something just over 13 volts on the DIC. If you haven't driven it for a few days, then the alternator will probably put out something over 14 volts to recharge the battery. Also, the starter draws a fair amount of current to start the car, so the voltage will generally show a higher charge rate for a few miles after starting the car until the battery is fully charged again. The DIC gauge is not a highly sensitive unit but it gives you a good indication of the state of the battery and charging system. If you show something less than 12 volts or over 15 volts, then it's time to have the system checked with something more useful than the DIC.
Good info, thanks. I was wondering why it showed higher after start then drops to around 13.9. At first I thought my battery was going bad.
