Wheel spacers
Old Aug 18, 2015 | 12:18 AM
Kenabinkport's Avatar
Kenabinkport
Default Wheel spacers
I have some larger than stock(295/35/19) rear tires and they rub on the inside when going over large bumps. The only option I have found so far is a 1/4" drm spacer that goes for ~$130, does anyone know of anything in 1/8 space that maybe goes for a bit less $.
Thank you.
Old Aug 18, 2015 | 12:32 AM
6speedsteve's Avatar
6speedsteve
Check Summit or Jegs, Gorilla makes an 1/8" spacer.
Old Aug 18, 2015 | 12:04 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
I use 1/8" spacers in my car. I have an extra set i can send you for $15 shipped. I run c6 z06 wheels on the car with 325 / 30-19.
http://www.corvetteflorida.com/forum...d.php?t=102573
Old Aug 18, 2015 | 05:33 PM
dbarrym's Avatar
dbarrym
Thank you.
I bought two pairs of 5mm hub-centric machined aluminum spacers from Amazon last weekend - arrived yesterday and they look great. They were $24 for a pair - see
here here
These are about as thick as you can safely go with stock studs, FYI...and I would suggest not using a cast, non-hub-centric type spacer. IMHO.
barry
Old Aug 21, 2015 | 12:36 AM
Kenabinkport
Originally Posted by dbarrym
I bought two pairs of 5mm hub-centric machined aluminum spacers from Amazon last weekend - arrived yesterday and they look great. They were $24 for a pair - see here.
barry
I just ordered those today, I'm looking forward to rub-free speed bumps.
Old Aug 21, 2015 | 12:56 AM
dbarrym's Avatar
dbarrym
barry
Old Aug 21, 2015 | 03:08 AM
Cliff8928's Avatar
Cliff8928
Motorsport Tech will make custom spacers to your spec for $25-$35/ea
To Wheel spacers
