Offset Question
Old Aug 18, 2015 | 12:30 PM
corvettekeys's Avatar
corvettekeys
Default Offset Question
I am looking to run a new wheel setup and have an opportunity to get a good deal on some wheels that have a lower offset than most setups I have seen. I have used the offset calculator and it looks like they will work. But I wanted to see if anyone has a similar wheel setup and If they would post a picture of them on the car.
Old Aug 18, 2015 | 12:37 PM
corvettekeys
Specs on Wheels
Front
18x8.75 +33
Rear
19x10.75 +35
Old Aug 18, 2015 | 12:42 PM
Black 02's Avatar
Black 02
I would personally keep looking. The widths are fairly narrow. Who measured the widths by the way? Typically, wheel widths don't have 3/4" measurements. Curious if they measured inside the barrels or outside. To me, they sound like BMW fitment; which is wrong for the car.
Old Aug 18, 2015 | 01:04 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Most likely 8.5 and 10.5" wide wheels.
Oem 8.5" fronts are +56mm and 10.5" rears are +58mm. Those will stick out quite a bit.
Old Aug 18, 2015 | 03:28 PM
ezrider4u2's Avatar
ezrider4u2
Old Aug 18, 2015 | 04:17 PM
I know I'd keep looking for a set that would fit better.
To Offset Question
