exhaust drone?
Old Aug 24, 2015 | 03:59 PM
firstvette99's Avatar
firstvette99
Default exhaust drone?
does the borla stinger drone?
if so what aggressive exhausts don't?
Old Aug 24, 2015 | 05:01 PM
Fcar 98's Avatar
Fcar 98
PRT'S, Very little drone. Around 1500 rpm. You'll get use to it, because the sound the rest of the time is great. I get a lot of compliments on the sound of the PRT'S
Old Aug 24, 2015 | 08:29 PM
schulte26's Avatar
schulte26
I drove from Maine to Baltimore and back twice this summer with my new Borla Stingers (2400+ total miles) I opted to not install the X-pipe. There was absolutely no drone....just that great mid 60s throaty exhaust note and super gas mileage (80 gallons of gas for 2400+ miles). Love my stingers !
Old Aug 24, 2015 | 08:31 PM
guido7834's Avatar
guido7834
There's no such thing. You either hear them or you don't! lol I love my Borla Stingers!
Old Aug 24, 2015 | 08:49 PM
CQRT's Avatar
CQRT
Billy Boat PRTs are pretty good . . .I have the Route 66 on my C5 and C6 and there's no drone, but they're also not very loud - - -the PRT's have a great exhaust note.
Old Aug 24, 2015 | 10:58 PM
cooter99's Avatar
cooter99
Following along
Last edited by cooter99; Aug 24, 2015 at 11:01 PM. Reason: Was high jacking the thread
Old Aug 24, 2015 | 11:02 PM
StingrayRebel's Avatar
StingrayRebel
what mods do you have done to your car?... that can be a factor to consider... corsa xtremes don't drone, I had them when my car was bone stock besides the xtremes and it is now highly modded and still sounds great with no drone
Old Aug 24, 2015 | 11:09 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yes....LT's ....no cats, Stingers.....its annoying...if you wanna have a conversation....
otherwise....
Old Aug 24, 2015 | 11:30 PM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
I had prt's before I moved up to 3 inch and agree with Frank on the no drone part. I would also look into the Corsa Extremes, if neutron gave a good review then that's worth a close look. I currently have LG big 3's and they came with 4 tips but the passenger side tips were welded crooked so I had my muffler shop cut them up and just leave two tips. They droned before I had them altered now they don't at all.
Old Aug 25, 2015 | 01:33 AM
imlowr2's Avatar
imlowr2
I found it interesting. I just purchased the Borla Stingers and was calling around to various muffler shops asking what they charge to install them. One of the popular muffler shops stated, "since you have Borla's, it will be about 1 hour charge of $65. If you had Corsa's or other, I'd charge you more. We never have issues with Borla exhaust and fitting properly. The others can be difficult to install." I actually had a quote of $350 to install the exhaust system. Another quoted me $250 and said he would recommend I take it to a expert Corvette mechanic to install the system because you have to lower the sub frame on the car to get the exhaust out. What???? I never heard that before... I'll be checking with a friend who has a lift, perhaps the both of us will be able to lower the subframe. What ever that is???
Old Aug 25, 2015 | 10:13 AM
chassed's Avatar
chassed
I guess that makes me an expert Corvette mechanic...
I have both removed and installed exhausts in my garage on Jack stands...not to mention a cam swap....
come on man...its not difficult....
Old Aug 25, 2015 | 10:25 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
GHL Bullets do not drone. But try to find them. I have a set on my 2000 6 spd Coupe.
Old Aug 25, 2015 | 10:31 AM
02Zvert06's Avatar
02Zvert06
love my stingers, going with long tubes to make them louder soon
Old Aug 25, 2015 | 10:47 AM
gulfstrings's Avatar
gulfstrings
Okay ... I admit my ignorance. What the heck is "exhaust drone?"
Old Aug 25, 2015 | 10:50 AM
2003RedVette's Avatar
2003RedVette
You do not need to lower the subframe to remove/install the aftermarket or stock exhaust. Muffler shops should charge $50-$100 to do it on a lift. If you have an Auto, there is a small cover plate on the passenger side that has to be removed. I've done this in my garage on jackstands, and you do have to raise the back of the car up scary high, but with the right stuff, it's not bad at all. I've done it over 3 times now, after I finally decided on Corsa Extremes, and it takes about 45 minutes or so. I also found a loading dock around the corner that worked too.
Old Aug 25, 2015 | 10:59 AM
Fcar 98's Avatar
Fcar 98
I had my mechanic do it that works on all my cars.He removed the stock system in one piece and installed the PRT'S with no problems.
To exhaust drone?
