under hood led light
Old Sep 1, 2015 | 07:40 AM
rwlc5's Avatar
rwlc5
Default under hood led light
Does anyone know the procedure for installing one of theses? If you hook the loops on the end of the light over the factory mounting points the light will face side ways instead of down. It doesn't seem like the loops can be bent. Do you have to bend the mounting tabs? Has anyone done this that can offer advice on the proper way to do it?
Old Sep 1, 2015 | 08:09 AM
jjc508520's Avatar
jjc508520
I picked up one in Carlisle I'll be trying it soon...
Old Sep 1, 2015 | 04:28 PM
SuperVetteC5's Avatar
SuperVetteC5
You have to modify the tabs on the light fixture. Bend them over and use a dremel to put notches in the tabs that the wire loops on the bulb will hook in to. Did two of these this way. Works great with no issues.
Old Sep 1, 2015 | 10:34 PM
dbarrym's Avatar
dbarrym
I posted some pics showing how I solved this here.
barry
Old Sep 1, 2015 | 10:58 PM
Here's some info:
File Type: doc
Old Sep 2, 2015 | 03:05 AM
john8642's Avatar
john8642
Radioflyer sells a nice LED under hood light.
Old Sep 2, 2015 | 07:55 AM
striper's Avatar
striper
I used the bulb from Radioflyer. It fits in like stock, makes a lot more light.
Old Sep 2, 2015 | 12:20 PM
rwlc5's Avatar
rwlc5
I checked out the Radio Flyer bulb. I think I will go with that since it does not require any modifications. Anybody want to buy an unused Corvette Mods bulb?
Old Sep 2, 2015 | 04:26 PM
GoldenFlame's Avatar
GoldenFlame
This,. I used the entire CREE setup that he sells on my car.. Everything is BRIGHT lol
To under hood led light
