Rear view mirror question
Old Sep 9, 2015 | 10:30 PM
Skrilla's Avatar
Skrilla
Default Rear view mirror question
I was thinking of changing my stock rear view mirror to the tinting one.Does anyone know if it is just a plug and play swap?
Old Sep 10, 2015 | 08:01 AM
Electron2002's Avatar
Electron2002
Originally Posted by 8VETTE7
Mirror will mount but the wring to the base mirror has 4 pin connector and the day/night mirror is a 7 pin connector. You would have to have the additional circuits and wiring to make it work.
Skrilla would not "have to have the additional circuits". The three circuits that are missing are: 2 circuits that would control the dimming of the LH outside mirror and one for backup lamp input (forces mirror to un-dim when in reverse). None of these circuits are an absolute must have for the basic operation of an autodimming mirror.
Skrilla would definitely need to install the 7pin connector. The four circuits that are present are all vitally important for the operation of the oem autodimming mirror
12v constant
12v ignition switched
12v door switch input
ground
