AC shut off
Old Sep 13, 2015 | 07:12 PM
Deneb's Avatar
Deneb
Default AC shut off
It has been a great summer with my 2004 c5. However, when I shut the driver's door my AC turns off. Otherwise, it stays on while driving. Does anyone know what causes this? I will pull codes as soon as possible.
Old Sep 13, 2015 | 09:32 PM
bjones7131's Avatar
bjones7131
I have noticed mine do that as well, car and air running, get out and close door and air shuts off. I bet it is some sort f feature to prevent something. Look forward to response
Old Sep 14, 2015 | 02:34 PM
Deneb's Avatar
Deneb
That's a relief. Thanks for the response. Has anyone else noticed the AC shut off?
Old Sep 15, 2015 | 11:43 PM
Deneb's Avatar
Deneb
I'm getting, 99 hvac b0367 h code. GM part #89018365 seems the solution.
Old Sep 16, 2015 | 08:50 PM
Deneb's Avatar
Deneb
Nice save! I followed the link, followed the instructions, and now the AC stays on. Thanks a million.
Old Sep 17, 2015 | 06:33 AM
dadaroo's Avatar
dadaroo
I find it hard to believe recalibrating the actuators is keeping the HVAC unit from shutting all A/C off when you close the door.
Old Sep 17, 2015 | 01:29 PM
Deneb's Avatar
Deneb
Well, it is true. Tested on two separate drives. When the fuse was pulled and put back in, the corvette went through a series of resets on the dic. Tire pressure was unknown for the beginning of the first test and the AC went though a series of auto states. At first I thought I had made the situation worse, but everything returned to normal. I will report back if anything changes.
Old Sep 18, 2015 | 06:07 AM
dadaroo's Avatar
dadaroo
Thanks. That is very strange. I can't figure out the connection.
Old Sep 25, 2015 | 10:44 PM
Deneb's Avatar
Deneb
Well the code is back, but the AC works when using the door. When I clear the code, the vent auto adjust. I'm stumped by the odd behavior.
Old Sep 26, 2015 | 10:05 AM
Lee DeRaud's Avatar
Lee DeRaud
A/C settings are part of the seat memory, right? Bad connection at the door making it switch to one of the other two configurations?
Old Sep 26, 2015 | 10:58 AM
bjones7131's Avatar
bjones7131
I don't think so but i am not a guru but find it hard to think ac and seat memory are related. I had my ac shut off when i opened and closed door twice but haven't tried it lately. It hasn't bugged me to the point of chasing it down. Will b following this
Old Sep 26, 2015 | 11:48 AM
Lee DeRaud's Avatar
Lee DeRaud
Temperature/mode settings are saved to the seat memory, as are radio tuning/mode for the factory Bose head. People (including me) tend to call it "seat memory", but it's a more general "personalization memory". From the owners manual:
If your vehicle has this feature, MEMORY can store and
recall the settings for the driver’s seat position, the
outside rearview mirror positions, telescopic steering
column (if equipped), radio presets, tone, volume,
playback mode (AM/FM, tape or CD), last displayed
station, compact disc position and tape direction and the
last climate control setting.
Old Dec 4, 2015 | 07:35 PM
Deneb's Avatar
Deneb
I will try setting my seat when below 32 degrees to see I can discern differences.
To AC shut off
