Charge System Fault
Old Sep 17, 2015 | 04:22 PM
Rockstar17's Avatar
Rockstar17
Cruising
Default Charge System Fault
2000 C5 Charge System Fault... Checked battery, alternator and starter,all good. Some forums say the ground wires can anyone direct me to where they are or an alternative thing to check. Seems like a common problem. Happens most of the time and is more annoying than anything else. Does not seem like it is affecting anything
Old Sep 17, 2015 | 04:37 PM
DetroitPlac's Avatar
DetroitPlac
Mine does it if I don't hold the key on long enough, but it starts anyway. Pretty common, I wouldn't worry about it.
Old Sep 17, 2015 | 04:41 PM
73Corvette's Avatar
73Corvette
https://www.corvetteforum.com/forums...ast-night.html
Old Sep 17, 2015 | 04:45 PM
Rockstar17's Avatar
Rockstar17
Cruising
Just real annoying
Old Sep 17, 2015 | 04:53 PM
Rockstar17's Avatar
Rockstar17
Cruising
Thanks, i'll try it. I cleared PCM code 1638
Old Sep 17, 2015 | 05:16 PM
Rockstar17's Avatar
Rockstar17
Cruising
My voltage is always above 13
Old Sep 17, 2015 | 07:28 PM
Rockstar17's Avatar
Rockstar17
Cruising
Came back on
Old Sep 17, 2015 | 07:56 PM
jdvann's Avatar
jdvann
How did you check your starter wire? Underneath for movement or loose main wire?
Old Sep 17, 2015 | 10:26 PM
73Corvette's Avatar
73Corvette
How did you check your battery voltage?
Old Sep 17, 2015 | 11:18 PM
73Corvette's Avatar
73Corvette
Did it for you...
https://www.corvetteforum.com/forums...tion-long.html
Old Sep 18, 2015 | 07:22 AM
Rockstar17's Avatar
Rockstar17
Cruising
Didnt check the wires. I had the starter tested, found Bill Curlee post with schematics and going to check today
Old Sep 18, 2015 | 07:23 AM
Rockstar17's Avatar
Rockstar17
Cruising
Originally Posted by 73Corvette
Thanks, i actually found that and printed it. Going to run through it today. Hope for the best! Thanks for the help
Old Sep 18, 2015 | 07:25 AM
Rockstar17's Avatar
Rockstar17
Cruising
Diagnostics in the car as well as at Auto zone and had a charger on it read 100%
Old Sep 18, 2015 | 08:07 AM
73Corvette's Avatar
73Corvette
So, what is your battery voltage? The DIC may not be right.. AZ just said 100%,,, so, you need to measure your battery voltage at the battery with a voltage meter...
C5 battery charge loss chart
A fully charged battery should be 12.6v or more.
If the battery is
12.5 = 85% charged
12.4 = 65%
12.3 = 50%
12.2 = 35%
12.1 = drained
Old Sep 18, 2015 | 08:33 AM
calvins's Avatar
calvins
Oldtimer
AND with the battery disconnected!
If the battery is
12.5 = 85% charged
12.4 = 65%
12.3 = 50%
12.2 = 35%
12.1 = drained
Old Sep 18, 2015 | 08:50 AM
dadaroo's Avatar
dadaroo
Guys, P1638 is the feedback from the alternator to the PCM on the duty cycle. That is the ratio of alternator voltage ON and OFF time to maintain charging within a predetermined range.
One of several things are going on.
Wiring or connector issue
Alternator issue
PCM issue
If the alternator is charging correctly then resolving this is not a high priority from a reliability issue.
Could be an issue with a connection at the alternator of PCM. That is easy to check at the alternator.
Charging System
Mr. Sam
Old Sep 18, 2015 | 09:49 AM
Rockstar17's Avatar
Rockstar17
Cruising
If the battery is
12.5 = 85% charged
12.4 = 65%
12.3 = 50%
12.2 = 35%
12.1 = drained
My charger measures the voltage during the cycle and when i first put it on. First on it measure 13.2. Fully charged was over 14
To Charge System Fault
Old Sep 18, 2015 | 09:59 AM
dadaroo's Avatar
dadaroo
Don't ever try to run the car with no battery. You can end up smoking all your electronics from overvoltage issues.
Old Sep 18, 2015 | 12:20 PM
73Corvette's Avatar
73Corvette
Alternator issue
PCM issue
Charging System
Mr. Sam
Thank you Sam... I was just trying to establish that he had a fully charged battery first... then have him pull codes again to see if the P1638 popped up again... still learning about the codes/diagnostic/ and fix I would probably have waited for someone with more experience like yourself to jump in and help with that part of it... which you have...I learn something new with almost every scenario... Thanks again!
Old Sep 19, 2015 | 06:31 AM
dadaroo's Avatar
dadaroo
OP, don't go back to the dealer until you do this. Remove the connector at the alternator where the 3 wires connect. Turn the ignition to ON (don't start the car). Measure voltage at the small Red wire. This is the RED wire next to the empty cavity in the connector.
You should get 5 volts.
If you do get that 5 volts then your PCM is OK and you have an alternator issue that is causing P1637.
Just like I the link I provided.
Mr. Sam
