Convertible night mare
Old Sep 26, 2015 | 02:32 PM
nylben's Avatar
nylben
Default Convertible night mare
I have a 1998 convertible - the other day I wanted to put the top down and went to press the release switch behind the driver's seat on the underside of the deck lid. When I touched it it came apart - a yellow button and a small spring are the only parts I came up with. I've ordered a new switch but the dilemma now is how to replace it. I've got a full set of shop manuals for the car, but there is no information on the switch replacement. I got the lid open with the manual release cable, but I don't know how to replace the switch. Can anyone help?
Old Sep 26, 2015 | 02:45 PM
jd911's Avatar
jd911
Originally Posted by nylben
I have a 1998 convertible - the other day I wanted to put the top down and went to press the release switch behind the driver's seat on the underside of the deck lid. When I touched it it came apart - a yellow button and a small spring are the only parts I came up with. I've ordered a new switch but the dilemma now is how to replace it. I've got a full set of shop manuals for the car, but there is no information on the switch. I can't open the lid and can't get at the release to try and open it. Can anyone help?
My bad. Old fart moment. Reading comprehension deficiency.
Jim
Old Sep 26, 2015 | 05:18 PM
David Shiel's Avatar
David Shiel
Default Yep, simple as that
Originally Posted by 8VETTE7
All the switch did was connect the ends of the two wires together. Pop the wires off the remains of the switch and touch them together and the tonneau should pop open. The two wires ground a circuit in the BCM that tells the BCM to releases the latch.
and right on advice.
Replacing the switch itself should be a snap. I did learn the hard way when cleaning the grounds on my previous 01 to disconnect the battery when messing with electricals, but it should not be necessary for this replacement.
Old Sep 27, 2015 | 07:56 AM
dadaroo's Avatar
dadaroo
I hope you know your Owners Manual tells you where the manual release cable is.
Old Sep 27, 2015 | 10:26 AM
Marine One's Avatar
Marine One
He addressed that in the last sentence of his original post:
"I got the lid open with the manual release cable"
Old Sep 27, 2015 | 10:53 AM
dadaroo's Avatar
dadaroo
Old Sep 27, 2015 | 11:41 PM
old stingray's Avatar
old stingray
To Convertible night mare
