C5 Washer Fluid Hose
Old Sep 28, 2015 | 01:25 AM
02GoldVette's Avatar
02GoldVette
Default C5 Washer Fluid Hose
Hey what's up, so my washer fluid hose (pictured below) seems to have broken/cracked (about 3 to 5in. piece. So my questions are -
Is it a quick fix?
Can I get the replacement hose from any auto store such as Autozone
Do I have to replace the whole hose or just enough to fix that small piece?
Let me know if you can help me out. It's not a main problem, but I just want to make sure I do it right.
Old Sep 28, 2015 | 02:59 AM
Martinez310's Avatar
Martinez310
Veteran: Marine Corps
St. Jude Donor '14-'15,'19
i had the same problem years ago i replace the entire line with small silicone hose from auto zone . those tend to brake over the year because they are made of plastic. i think it a pretty easy job it took me 1 hour to fix because i had to remove the windshield wipers in order to connect the lines
Old Sep 28, 2015 | 06:26 AM
I would think an auto parts store could set you up.
Old Oct 26, 2015 | 01:57 AM
02GoldVette
So after trying a replacement hose from Autozone/Oreilly's, it just ended up falling out after awhile. Does anyone know where to get an OEM washer fluid hose from?
Old Oct 27, 2015 | 11:44 PM
02GoldVette
Bummmppppppppppp......
Old Oct 28, 2015 | 12:59 AM
grantv's Avatar
grantv
Vettenuts.net or Cultrag?
Old Oct 28, 2015 | 09:41 AM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We have OEM hoses in stock that are used and in good shape. Let me know and we can get you one on the way.
Marc
Old Jul 11, 2016 | 01:55 PM
123Gone's Avatar
123Gone
Old thread, but I just replaced my washer fluid hose like the one shown in post #1. Here's a link to what I bought. You want 5mm OD, 3mm ID.
http://www.fluorostore.com/products/...polymer-tubing
Old Nov 16, 2016 | 06:45 PM
levasseurjohn's Avatar
levasseurjohn
5th Gear
1998 C5 - I was missing the washer hoses when I purchased the car. I can't find where the larger hose from the pump enters the channel where the wiper motor and linkage is. Must be a hole somewhere but I can't find it.
Old Apr 30, 2017 | 12:31 AM
Luigi Cappel's Avatar
Luigi Cappel
4th Gear
Every time I fix or replace a section of the house, another piece comes off. The latest is the bottom hose underneath the sensor. I put in a new section of hose and its now leaking from where the hose goes into the container. Is there some sort of grommet or seal there? I'm in NZ and if its a specialist part, I'm not super keen on taking the whole reservoir out and find I need a special part where the hose goes in that I can't buy in New Zealand.
To C5 Washer Fluid Hose
