Proper starter alignment
https://www.corvetteforum.com/forums...post1590317076
HI there,
First, the fact that the short/long bolt starter is any less reliable is garbage. There is not one documented test that there has ever been an issue.
Second, the starter is a simple one, use the one out of the trucks.
Fact is, unless there is actual internal engine binding, there is ONLY ONE THING that caused a broken snout on a starter. INCORRECT INSTALLATION OF STARTER!
People do not torque the fasteners correctly, or dont use the correct bolts or attempt to use shims where SHIMS SHOULD NEVER be used.
Why you would change the starter if its not giving you an issue????
Maybe if the engine is heavily modified with higher compression, I can see that.
Starter bolt torque is 37 ft lbs. If you over torque the fasteners, you will distort the snout. If you use the incorrect bolts, you will misalign the starter to the block and THEN you can damage the block.
12592294 is the starter for the 5.3 LM7 truck engine that will work with 2 equal length bolts.
But as I said in the beginning, only MISINSTALLATION or internal engine binding can create this type of failure.
Allthebest, Paul
GM World Class Certified Service Technician.
Like us on Facebook: www.facebook.com/corvettemechanic
Twitter: www.twitter.com/GMvettemechanic
http://www.thecorvettemechanic.com/f...arter-question
If there were no shims on the stock starter, why would I put them on then, just saying. Everything should be bolt up and go. Remanufactured just use newer guts but keep the current casting. Just saying.
I agree with reliable but the OEM design with one short and one long bolt has a history of breaking the block under certain conditions. Backfire, hydro lock, etc. Never heard of it being misalignment but maybe if the starter was the problem. The design does not require a shim.
Well documented, if you don't believe it just ask Bill Curlee. I even created a Thread on it.
Mr. Sam
Bill had a Navy Nuke welder good enough to do it in place.
There is a vendor who sells a "fix" but it is two or three times the cost of starter. I'll post that also.
Mr. Sam
I was lucky that my GMPP extended warranty replaced my engine, but I still hold my breath every time I turn the key 7 years later!
I think there may be some logic to replacing with the 2-long-bolt starters if it is indeed the starter flange on the short-bolt side of the starter that is the root of the problem, but again as stated above I have not seen any statistical data to confirm that as an absolute solution.
Where my starter (or block) failed... chicken or egg?
https://www.corvetteforum.com/forums...the-block.html
Starter Bridge:
http://2ndsucksracing.weebly.com/web-store.html
Mr. Sam
