Anyone use Snow Tires?
Old Oct 19, 2015 | 09:31 AM
Tim1137's Avatar
Tim1137
Default Anyone use Snow Tires?
Hello all,
I live in New England, and I'd like to consider snow tires to get me around this winter in my new to me 1997 Corvette. Curious if anyone else uses snow tires, and what sizes you chose. I know its not ideal to drive in the snow, but for reasons beyond my reasonable control, I may get caught in the snow with it sometimes.
Appreciate any help you can provide!
Old Oct 19, 2015 | 10:46 AM
JR-01's Avatar
JR-01
Originally Posted by Tim1137
Hello all,
Do they make snow tires for C5s? All-seasons may be as close as you can get and many people do use those.
Old Oct 19, 2015 | 11:18 AM
VettesGoneWild's Avatar
VettesGoneWild
I live in New England also (Central MA) and think if you can find snow tires to fit, you should stud them for sure. Chains perhaps. If you live on Cape Cod or coastal areas you may get away with all seasons, but inland, not. If you do drive it in the snow it probably will get a lot of snow scooped up under the front end. Instead of snow tires spend a little more for a beater car or truck for those days-then no worries about the Vette.
Old Oct 19, 2015 | 11:20 AM
Tim1137's Avatar
Tim1137
There is a Pirelli made in the OEM rear size, but I was actually hoping to go down to something like a 255/45/18 tire in the rear. The more narrow, the better. Can't go much lower than that on a 9.5 width rear wheel though. I believe I'll need to change the front size too though to keep the ABS/Traction control happy though? Not sure if there was a certain set of sizes that are most popular
Old Oct 19, 2015 | 11:22 AM
Tim1137's Avatar
Tim1137
I appreciate the feedback. I live in southcoast MA, but I have a 60 mile commute every day so If I get stuck at work and need to drive home in snow, its a 30 mile drive.
Normally I'd just buy a $1,000 honda civic beater, but the issue for me is space, I have no room for another car. Literally, no where to put it.
Old Oct 19, 2015 | 11:35 AM
JR-01's Avatar
JR-01
I hope your Vette survives the winter.
Old Oct 19, 2015 | 11:57 AM
Tim1137's Avatar
Tim1137
Me too hahaha. I've been driving RWD sports cars for the past 5 winters with great success. I'm not too worried about it, as long as I'm prepared. My Honda S2000 with snow tires ( No traction, no ABS) got around in heavy snow better than my fiance's Acura TSX with all the gizmos and gadgets this past winter.
Old Oct 19, 2015 | 12:25 PM
73Corvette's Avatar
73Corvette
I would REMOVE the air dams... you won't need them for sure in the winter anyway... that way your not plowing snow...
Old Oct 19, 2015 | 08:47 PM
All seasons might be your best bet. My car stays in the garage all winter so I don't worry about driving in snow, but something like the Michelin AS tires should work well for you if you have to drive your C5 in snowy weather.
Old Oct 19, 2015 | 11:33 PM
Cliff8928's Avatar
Cliff8928
Are you looking to mount these on a second set of wheels? I wouldn't think it would be hard to find some narrower (Camaro-width?) wheels
Old Oct 20, 2015 | 08:43 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by JR-01
......Do they make snow tires for C5s? All-seasons may be as close as you can get and many people do use those.
Goodyear used to have snows in C-5 sizes, but since the C-5 is now 2 generations old, and in all honesty, so few guys drive them in winter, I think they stopped making them.
On a VERY serious note, in order to be REALLY effective, a snow tire needs to be narrow, to be able to punch through the snow. Tires in Corvette sizes, are way too wide, to work really well.
Old Oct 20, 2015 | 09:05 AM
JR-01's Avatar
JR-01
You got that right. Here in Wisconsin you don't see any Corvettes on the road in winter.
Old Oct 20, 2015 | 09:35 AM
leadfoot4's Avatar
leadfoot4
WHERE do you live, and HOW MUCH snow do you get? There are a lot of members here, who talk about "winter driving", yet they live in "mid Atlantic" states, where 1" of snowfall is considered a "blizzard"....
Old Oct 20, 2015 | 10:07 AM
Angel23's Avatar
Angel23
Drove a 4th gen Camaro and an 04 gto for 7 out of the last 8 winters here in ct. Good snow tires make all the difference. Anything less then 4 or 5 inches (on the actual road surface) and I was fine. Both instances tires cost 1200-1500 not including spare rims. Got me to thinking last year when I got the vette to just buy a winter beater. Regardless of the control I have over my vehicle, it only takes one other driver to total your car. Almost learned the hard way when some one in an s2000 slid across the road head on towards me in the gto. Luckily no one was behind me because the snow tires were enough to stop me quickly and safely as the guy slide across the front of me into the trees.
Old Oct 20, 2015 | 12:21 PM
Mike98SilVert's Avatar
Mike98SilVert
Anything over 4 inches you should leave it where it is and call a cab. A good set of snow tires will help (if you can find them) but the car is too low for anything more than a few inches and forget about getting through drifts and those mounds left by the snow plows. A good set of snow tires with rims and balancing will cost as much as a beater.
Old Oct 20, 2015 | 12:33 PM
Angel23's Avatar
Angel23
Old Oct 20, 2015 | 01:18 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
The problem is, in MA, when you get 4 inches, it's 4 inches on the ground for many days, maybe weeks. I used to consult with a firm in Framingham. During the winter, snow comes down and stays there. Here in NC when we get snow, it's gone in two days max. OP, I feel your pain. No easy answer. Consider a narrower wheel than the stock wheel, maybe that will allow a snow tire. Don't forget to check the offset.
Mike98SilVert made a good point about the snow plow effect. Maybe remove the air dam from the front? Might want to ask others about that.
To Anyone use Snow Tires?
Old Oct 20, 2015 | 04:30 PM
jhopper408's Avatar
jhopper408
Try some snow chains. Lol
Old Oct 20, 2015 | 05:44 PM
leadfoot4's Avatar
leadfoot4
Originally Posted by Angel23
..... just buy a winter beater. Regardless of the control I have over my vehicle, it only takes one other driver to total your car.
Bingo!!!
Plus, if they use road salt in your area, that can wreak havoc with your car....
Old Oct 20, 2015 | 05:46 PM
Monkey D. Luffy's Avatar
Monkey D. Luffy
SNOW TIRES
