Help with N2MB wot box
Old Oct 23, 2015 | 12:07 PM
Quicksilver2003's Avatar
Quicksilver2003
Default Help with N2MB wot box
Is anyone successfully using the n2mb wot box?? How did you wire up the yellow wire?? Also what are your settings for the software?? So far everything works except the 2step. Any help would be greatly appreciated.
Old Oct 24, 2015 | 12:32 AM
CactusCat's Avatar
CactusCat
Might have better luck posting this in the performance section or the forced induction/nitrous section. GL with your search.
Old Oct 24, 2015 | 09:54 AM
john8642's Avatar
john8642
Here's another thread about it. Might have some answers.
https://www.corvetteforum.com/forums...th-wotbox.html
Old Oct 24, 2015 | 01:36 PM
Quicksilver2003
Well, I got it working today. It's awesome. But it's not plug and play at all. The good thing is that it has lots of features that would normally take several different boxes. If you buy a Wotbox, all I can say is download the software instructions and get a real good understanding of them. But the Wotbox works like a champ.
Old Apr 17, 2019 | 07:09 PM
almosttherec5's Avatar
almosttherec5
My two steps won’t work, my throttle on my gas will not read down,
it reads 2.9 volts down and 4.0 up and should read 0 and 5... can anyone help why my pedal down is not 0 v
Old Apr 17, 2019 | 07:36 PM
493lszosix's Avatar
493lszosix
Check and see if your clutch and tps inverted boxes are checked on your screen
Old Apr 17, 2019 | 10:10 PM
almosttherec5
Thanks, I figured it out now... it was that but then it was the tps V threshold, Had to change it so it knew it was throttle down
thanks
To Help with N2MB wot box
