Removing rear "CORVETTE" inserts
Old Oct 27, 2015 | 12:37 AM
1975greenconvertible's Avatar
Default Removing rear "CORVETTE" inserts
Anyone have experience with removing aftermarket sticky "CORVETTE" letter inserts in the rear bumper? They were on it when I bought the car, but I want to remove them. Any tips before I start working on it this weekend? I'm thinking start with a hair dryer and then use something to remove any glue residue?
Old Oct 27, 2015 | 12:43 AM
zachaeous's Avatar
zachaeous
Default removal of letters
I have used a heat gun (hair drier will work) and then I used goo-gone to remove glue. There are other products that will remove glue residue. If you can get into the letters a lot of the adhesives can be just rubbed off with pressure and using WD40 or something like it.
Good luck with your repair.
Old Oct 27, 2015 | 07:03 AM
Wichard's Avatar
Wichard
Someone rear ended me so I got a whole new bumper and I elected not to have the letters replaced. Not the preferred method...
Old Oct 27, 2015 | 10:19 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
No, but it worked...
Old Oct 27, 2015 | 10:25 AM
Hair dryer will soften the adhesive, then once you have the letters off, WD-40 or rubbing alcohol can be used to get any residue off the fascia. As mentioned, goo-gone is also an option.
Old Oct 27, 2015 | 10:39 AM
huesmann's Avatar
huesmann
Make sure you test the adhesive remover in an inconspicuous spot on your car, lest you remove finish with the adhesive!
As an alternate to the goo-gone and such, try some duct tape--stick a little duct tape on the adhesive (soften with heat gun first), then pull it up. Repeated applications will pull up a bit more adhesive each time.
Old Oct 27, 2015 | 01:03 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Agree with testing before using Goo Gone. Another product I've used (but not on the Vette) is Goof Off. But test it first.
Whatever chemical you use, wash off with water immediately after use. The residue can do damage when you think it's all gone.
Old Oct 27, 2015 | 01:09 PM
Black 02's Avatar
Black 02
I use a steam cleaner to remove factory badges. A hairdryer or heat gun would work too. Just be careful and don't get things too hot and you'll be fine.
Old Oct 27, 2015 | 03:14 PM
dbgoodwin's Avatar
dbgoodwin
The ones my friend made for me were just vinyl stickers so no adhesive.
Old Oct 27, 2015 | 03:44 PM
jjc508520's Avatar
jjc508520
Are they really ugly? I put the carbon-fiber (grey) ones on my pewter C5 (rear only) and they look great...
Old Oct 28, 2015 | 05:35 AM
SMT1004's Avatar
SMT1004
Park in sun 15 minutes, peal off using toothpick to get them started. Finish with 3M automotive adhesive remover. Put a coat wax on. Done. Takes 20 minutes.
To Removing rear "CORVETTE" inserts
