C6 Shift Boot
Old Nov 6, 2015 | 01:16 PM
bartsky's Avatar
bartsky
Default C6 Shift Boot
Does a C6 shift boot fit in a C5 properly?
Old Nov 6, 2015 | 01:19 PM
JEH03Vette's Avatar
JEH03Vette
I think the ring size where the boot attaches at the bottom is different on a C5.
Old Nov 6, 2015 | 01:23 PM
bartsky's Avatar
bartsky
That is what I am wondering because I have an MGW shifter with a C6 ****. So wondering if I buy a C6 shift boot, will in fit properly down into the radio bezel/console.
Old Nov 6, 2015 | 01:25 PM
bartsky's Avatar
bartsky
Like this one...
http://www.ebay.com/itm/2005-2013-C6...FVGceN&vxp=mtr
Old Nov 6, 2015 | 01:28 PM
JEH03Vette's Avatar
JEH03Vette
You could call Sandy at Vette Essentials. I recently order a new two-tone shift boot from them for my c5. I have a c6 shifter in the car and Sandy told me the boot would have a c6 top and a c5 bottom.
Old Nov 6, 2015 | 01:32 PM
bartsky's Avatar
bartsky
Very cool! I will do that.
Thank you...
Old Nov 6, 2015 | 01:45 PM
DinkyDonut's Avatar
DinkyDonut
It's very easy, but yes, you do need to swap the rings.
I recently put a stock C6 shifter and boot in a C5. It was as easy as taking the old C5 boot, undoing the staples and removing the lower ring, and then simple taking the C6 boot, wrapping it over the same ring and stapling it down.
Old Nov 7, 2015 | 11:20 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
When you pull the ring, you will see it is stapled to the boot.
Un-staple - staple new boot to ring
Reinstall
Regards
Chip
__________________
..................Click for
Old Nov 7, 2015 | 07:34 PM
SR-71's Avatar
SR-71
I've been running a C6 Z06 carbon edition ****, boot and shifter in my car for a few years. It's a simple swap.
Old Nov 9, 2015 | 09:32 AM
huesmann's Avatar
huesmann
I swapped a C6 shifter into my C5. The top of the stock boot was too narrow for the C6 ****, because the C5 boot just goes around the shifter shaft, not the ****. I trimmed the top of the boot til the hole was just big enough for the bottom of the C6 **** to fit, then re-stitched the seams (because they were unraveling). I went to the h/w store and got a rubber O-ring that was the same size as the groove in the C6 ****. Then I turned the boot inside out, stuck the **** through it, put the O-ring around the boot in the groove, then flipped the boot right side out. I then screwed the **** to the shaft and snapped the boot into the console/bezel.
To C6 Shift Boot
