Hi
Looking to change standard leather C5 steering wheel with a carbon fibre/leather grip "D" shape wheel. Looking for someone who may of changed their car and if the process is difficult. Is it just a matter of removing the airbag (obviously disconnect negative terminal) or do I need to remove dash moldings and surrounds. Cheers.
Hi
Pretty easy. A few screws from behind the airbag, the horn, ground, and the steering wheel nut. You will need a steering wheel puller. First time took about 30-35 min. 2nd time it only took about 15 min
Thanks for the replies. I will disconnect battery before I commence removal of old wheel (still in good condition) may list to sell to perhaps offset new wheel cost of $995.00. Expensive but looks great and I am sure will feel a lot better.
I'm attaching a steering wheel removal procedure that includes the proper sequence to de-activate the airbag. Just disconnecting the battery is not always a guarantee it will not go off. Please read this first.
