Pull key, wait 10...
Old Nov 16, 2015 | 01:07 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Pull key, wait 10...
Been happening a lot lately, what's the fix?
Old Nov 16, 2015 | 01:17 PM
Buy an LMC5 from Compliance Parts and install it. Should fix your column lock problems.
Old Nov 16, 2015 | 01:42 PM
73Corvette's Avatar
73Corvette
IF you've already done the LMC5 which you should have then you may need to do the "Brown Wire Mod"
If you don't have the LMC5 then you MUST get one put in... it is the ONLY true fix...
Call Richard at Compliance Parts and he will give you the BEST SERVICE in the industry... bar NONE
Old Nov 16, 2015 | 01:44 PM
Glasact's Avatar
Glasact
Lately I have been receiving this message on occasion too. I have already had the LMC5 installed when I bought the car. What am I missing?
Old Nov 16, 2015 | 02:01 PM
Bill Vett's Avatar
Bill Vett
Make sure the battery is fully charged
Clean resistor/puck on key or try another key.
Only keep ignition key on ring.
I'm sure other folks will have more detailed instructions.....
Old Nov 16, 2015 | 02:22 PM
Markm10431's Avatar
Markm10431
Parrothead
If the lmc5 is the column lock bypass, it's the first thing I did when I bought her. I was wondering if the keys could" wear out"
To Pull key, wait 10...
