New Tires' Issue?
Dec 1, 2015 | 07:42 PM
St. Jude Donor '15
Quote:
Originally Posted by
BayVette
Alignment specs attached
thx
Jerry
i would drop the right camber to -0.20 to match the left and raise the caster on the right to 7.20. see how it drives then.
Dec 1, 2015 | 07:50 PM
New Tires Issue
mrr23
Thanks for the recommendation! I have an appointment with the alignment shop on 12/9; I'll pass it on.
Jerry
Dec 2, 2015 | 08:03 AM
mrr23
Dec 17, 2015 | 01:29 PM
New Tires Issue
A third visit to the alignment shop still did not resolve the pulling issue; I left in disgust. My local, very talented, mechanic took a look. All 4 tires were incorrectly inflated; after remedying this problem solved! He also centered the steering wheel properly.
Thanks for all of the great advice!
Jerry
Merry Christmas!
Dec 17, 2015 | 01:32 PM
Dec 17, 2015 | 02:03 PM
St. Jude Donor '18
BayVette
...All 4 tires were incorrectly inflated; after remedying this problem solved! ...Thanks for all of the great advice!
Jerry
Merry Christmas!
Did your TPMS not alert you to your tire pressures being off?
Dec 17, 2015 | 02:06 PM
New Tires Issue
Sydwayz
Pressure wasn't off much, but each tire was different! Equalizing them made the difference.
thx
Jerry
Dec 17, 2015 | 08:01 PM
You still have a problem. I am running Michelins Pilot A/S , and even if the pressures are way different side to side, it does not pull to the left or the right. My take on this whole thing is simple - stick with Michelins.
Dec 17, 2015 | 08:50 PM
New Tires Issue
jackthelad
You are correct, next time Michelins!
thx
Jerry
Dec 17, 2015 | 09:39 PM
I was thinking of getting the BF's here shortly, may have to re-think this............
