New Tires' Issue?
Old Nov 29, 2015 | 08:08 PM
BayVette's Avatar
BayVette
Default New Tires' Issue?
I replaced my Michelin Pilots with BF Goodrich Comp-2 A/S tires 2 weeks ago. I noticed a slight pull to the left during sweeping turns to the right. I then had my 2003 convertible aligned at a very reliable shop. 2 test drives and adjustments later the pull remained. I returned a few days later. The tech tried 3 more times to get it right. The shop manager theorized the left front tire was defective. My very cooperative tire dealer graciously replaced it. The pull remains! To further complicate the issue the car tracks straight ahead on a level road! I'm not sure what to do next. I'd appreciate any insight/suggestions my forum friends can provide!
Jerry
Old Nov 29, 2015 | 08:28 PM
jackthelad's Avatar
jackthelad
Have any buddies with C5's? Try swapping with them to see if the problem goes away. You could just try swapping the fronts side to side - I know the tread rotation would be "wrong", but if the "pull" moves to the other side, it's the tires and not the car.
Old Nov 29, 2015 | 08:30 PM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Did you have them Road Force Balanced when installed?
Old Nov 29, 2015 | 09:14 PM
norcalace's Avatar
norcalace
Jerry
I think what you just described is called centrifugal force. Any car turning to the right is going to want to go back to the left until straight. If it's a hard tug you may have a caliper hanging up or the bracket is loose. How does it behave under medium to hard braking while going straight and or turning? Since it's tracking straight I would rule out the alignment and the tires. Keep us posted.
Old Nov 30, 2015 | 08:23 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Just for the sake of clarification, the "pull" started after you installed the new tires and had it aligned?
Old Nov 30, 2015 | 10:43 AM
aj98's Avatar
aj98
I replaced my Michelin Pilots with BF Goodrich Comp-2 A/S tires 2 weeks ago. I noticed a slight pull to the left during sweeping turns to the right. ... To further complicate the issue the car tracks straight ahead on a level road!
Do not take the next statement as sarcastic - in order to better identify the potential problem, perhaps you need to drive several different roads - or simply change lanes.
Why:
Roads are generally designed/built to shed water - no road is perfectly flat/level.
In order to shed water off the driving surface, roads are built/designed with slope left, slope right, or crowned (high in the center, lower at either curb).
this design feature will make a car pull or drift in the direction of the slope.
Additionally, the fat tires on the C-x will tend to follow any seams in the surface, which will also make the car feel like it is pulling/drifiting.
if you change lanes and the pull/drift swaps sides, then you know you are on a crowned road, and it is likely the road that is causing the pull, not the tires/alignment.
Many curves are designed with a slight bank, which both sheds water and help keep cars on the road/in their lane.
But depending on how fast you are taking the curve, and which way it is banked, physics and centrifugal force may feel like drift.
Old Nov 30, 2015 | 12:24 PM
BayVette's Avatar
BayVette
Default New Tires Issue?
Yes, the issue began after the new tires were installed
Jerry
Old Nov 30, 2015 | 12:26 PM
BayVette's Avatar
BayVette
Why:
Your points are well taken and thanks. My car did not have this issue until the new tires were installed. Maybe I have should have bought Michelins again?
Thx
Jerry
Old Nov 30, 2015 | 12:41 PM
leadfoot4's Avatar
leadfoot4
Thx
Jerry
Can you post your alignment specs? As "aj98" mentioned, most roads are "crowned". Many alignment guys add a little more caster to the passenger side of the car, to compensate for this, and the car runs straight. But maybe your guy went a little overboard, creating the "pull"....
Old Nov 30, 2015 | 03:02 PM
rrwirsi's Avatar
rrwirsi
When I replaced the tires on my DD, the exact same left pull occurred. Went back to the shop that does all my non vette repairs and rode with the tech. He acknowledged the pull but said the alignment was to specs. Redid the alignment but still pulled to the left. So he adjusted again not using the specs and all is now fine.
Old Nov 30, 2015 | 03:04 PM
BayVette's Avatar
BayVette
I am looking for the specs, but the tech tweaked the alignment 5 times w/o the machine! It's time for a ride along!
thx
Jerry
Old Nov 30, 2015 | 03:05 PM
BayVette's Avatar
BayVette
Default New Tires issue
I agree, it's time for a ride along!
thx
Jerry
Old Nov 30, 2015 | 03:48 PM
aj98's Avatar
aj98
Might also ask if they did a front align only, a 4 wheel align, or a thrust angle alignment.
Check pressure in each tire. If one is low, you'll get pull, too.
One time I got mine back and there was something like 42# in one wheel (compared to 28 or so in the other 3)
Old Nov 30, 2015 | 03:57 PM
BayVette's Avatar
BayVette
They did a 4 wheel alignment. My TPMS shows 30 lbs for all 4 tires..I'll check now with a high quality gauge.
thx
Jerry
Old Nov 30, 2015 | 11:29 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Tire sizes the same? Overall contact patch the same? I ask because a tire may have the same size specification, but certain brands can run wide and others narrow, and this can have a contact patch affect. If your contact patch changes, you could be finding ruts that you didn't notice before that can influence themselves as pulls or pushes.
Old Dec 1, 2015 | 04:09 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
thx
Jerry
He adjusted the camber and caster without a means to see how much it affected the toe setting? Wow way better than I'll ever be.
Have to be clear on this statement. Did you install tires and it started pulling left or was it after doing the alignment?
I want to see the after specs for the alignment he did.
Signed - the alignment guy
Old Dec 1, 2015 | 04:14 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
thx
Jerry
Does it want to pull right when you make a sweeping turn to the left?
What speeds is this happening at?
If its not pulling when driving straight, then i would look at what the toe settings are.
To New Tires' Issue?
Old Dec 1, 2015 | 05:07 PM
REDHOTS's Avatar
REDHOTS
Not knowing your tires sizes, ride height, drivers weight, sway bar preloads, and corner weights, all bets are off. Maybe now would be a good time to check corner weights on scales. I want to get mine checked sometime, even though it drives great.
Old Dec 1, 2015 | 06:24 PM
BayVette's Avatar
BayVette
Alignment specs attached
thx
Jerry
File Type: pdf
Old Dec 1, 2015 | 06:26 PM
BayVette's Avatar
BayVette
It only pulls during sweeping turns to the right. I feel it at most speeds, but it's more obvious on the freeway at 65 MPH or so.
thx
Jerry
