[Z06] 04Z valve spring poll
2004 was supposed to be the year the valve spring issue was resolved. That said, there are 5 recorded failures of 2004 models.
https://www.corvetteforum.com/forums...-failures.html
So I'm curious:
-How many of you "04 people" are rolling the dice?
-What is your build date?
-Mileage?
-Are you nervous if not replaced?
-If you did have a failure please note that also
Me:
Build date 09/03
46,000 miles
Rolling the dice so far, kinda nervous
Have springs and seals, thinking of replacing this winter
If you're that nervous get them replaced but I wouldn't worry about it personally.
So I'm curious:
-Mileage?
Me:
Build date 09/03
46,000 miles
I like to be safe so on stock LS6's I generally tell our customers you should do springs every other season on a stock car if you are going to heavily track the car 10-15 weekend events every year. This does not count any kind of mechanical over rev. If that happens change them then.
Street cars we have seen them come in here broken at 50, 55, 60, 65k with mixed street and light track use.
It is much cheaper to put a set of springs on it, than pull a valve out of a piston.
Previous owner claimed at 83k it broke a valve spring, leading to a dropped valve. It now has a crate motor with about 22k miles on it.. Just to be sure I will be putting in upgraded springs.
Will edit with build date
If you remove the oil cap you can see part of a spring.
Here are the part numbers if you have to make a change:
12499224 is the set of 16 springs
12482063 are the intake valve seals
12482062 is the set of exhaust valve seals
12637683 is the number for valve cover gaskets
I do still suggest spring replacement on a pretty regular basis for track cars, again it is just cheap insurance because in the heat of the moment there are always a number of over rev's that you just do not catch (unless you have a data system on the car) and do take their toll on the cars over time more so than a street driver.
There are only 5 Recorded instances located in this thread.
Username: Description of broken spring.
Speeed-Racer 2004: 04 Z06, broke the #7 valve spring at 21K miles. Under normal driving conditions (at the time). I was told this was a bit more rare on the '04's.
Badd LS6 2004: i have an 04Z and just had a exhaust valve spring bust on me this past summer
24hr Z06 2004: My #8 cyl. spring broke a little after passing the 15,000 mile marker on my 2004 Z16.. Almost always warmup the oil temp to 170 before getting on the car (have been a few times where I went above 4k but not past 5800)..
Rev limiter was set to 6900rpms, never missed a shift, nor have I ever hit the limiter.. Maybe went past 6700rpms once before this happened..
Day the #8 went, I was chasing down 2 bikes for about 10mins, and driving the car pretty hard.. Started to slow down, and about 5mins later it broke..
Mods.. Tune, intake, t-stat, and headers.. Good excuse to upgrade the springs, so now the car is ready for a cam..
RANsTRZ06 2004: I had on fail at about 45000 mile on a stock motor 2004. It took out the block.
Dude. 2004: This one does not have a link that I could copy the description of.
The main reason I posted this new question however (and why it's second only behind who hasn't done it yet) is about the build date. I was wondering if a particular run of 2004 models were the ones that failed. I wonder if some of the old springs carried on into 2004 models... and if so, the build dates of those cars.
